Hot shot max payload weight confusion!! help?
Discussion in 'Expediter and Hot Shot Trucking Forum' started by carptransport, Feb 8, 2019.
  1. carptransport
    carptransport Light Load Member
    63
    64
    Dec 11, 2018
    Port Saint Lucie, FL
    thank you, yes the coupler is rated @ 30k, i dont have to worry about killing the truck, its a lease from enterprise and i get a new one ever 60k so kill away, yes i figured the ball would be my weak spot, its also a gooseneck on 5th wheel rails unfortunately , and since im going to be going through a truck every 6 months upgrading the hitch isnt really an option!
    singlescrewshaker Thanks this.
  3. carptransport
    63
    64
    Dec 11, 2018
    my scale #s may be slight off as i weighed truck and trailer empty, and weighed the truck alone after installing tool boxes and filling the truck with all my extra equipment, will have to scale again with the trailer and the now loaded truck...
    the GVWR for the truck says 14,000, i can not find a GCWR as someone stated above, dont know where else it would be, but i am sure its more than 22.5k. i plated at 42k because FL has a range of 39-42999 at the same registration price and i was unsure of max load, but i still can not load at 20,700 because of the ball/hitch rating correct? i have to keep the trailer and load below the the 25k rated ball...
    what i am now assuming is dot will allow me to roll through at upto 39k distributed properly, but the goosneck ball is going to keep my load under 16,320 + 8680(empty trailer)=25k
    will DOT look at the coupler (30k) which is fine and the ball which is not (25k) at the scales? or just the axle #s?
  4. carptransport
    63
    64
    Dec 11, 2018
    yea ok.... the gvwr for the truck is 14k, so your saying i can only tow 8500 with a dually, think your #s are further off than mine... can not find a GCWR anywhere on the truck
  5. carptransport
    63
    64
    Dec 11, 2018
    i have my CDL so i am licenced for whatever, and FL doesnt care, they would let me plate it at 70k, they just want to collect the IRP registration fees...
  6. Miroh
    Miroh Light Load Member
    137
    49
    Oct 3, 2018
    That's just what your truck can handle total. You can load 8500 on your actual truck. But, then the trailer comes into play and then you add the GVWR of that to the GVWR of your truck and thats what you can safely haul. But, it has to be within the parameters of what your axles can handle. From your steers, drives and trailer axles. Figuring out how to distribute it all is a whole different ball game though.
  7. singlescrewshaker
    4,852
    42,408
    Dec 31, 2017
    Little Havana, FL
    Correct you can cross a scale at 39k, assuming all axles are legal, & new hitch good for 30k.. Can you get away with it with current hitch, probably. Could snap off to 1st time you hit the brakes really hard in a panic stop..
    You'll never find a GCVWR decal on the truck because it does not exist. Those tow ratings set by Ford are nothing but recommendations.
    So unless you can some how upgrade that 25k rail system and goose ball your only going to legally be able to cross the scales at roughly 34k lbs. That's just me assuming 25k gross trailer weight & 9k lb truck weight. Maybe a little more, maybe a little less.
    It all depends on the trooper or DOT man doing the inspection on how close they look over your coupling system. Also if your ever in an injury, or God forbid a fatality accident, they are going to go over your rig with a fine tooth comb looking for anything to put the blame on you, at fault or not. Also it's just not safe to run around pushing the limit, or exceeding & weight rating of the coupling components.
    Is the rail system attached to one of those in bed puck systems? Maybe you can buy a 30k rated 5th wheel that will drop into those, & just move it to the next truck in 60k miles..??
    Also, some of those rail mount goose ball plates are offset. They can be rotated 180° to move the ball closer to the cab, or closer to the tailgate. See if yours can be turned the other way, because I really don't like the lost of steer axle weight when the trailer is hooked up. You want all the weight you can get up there for maximum braking, & steering capability. You lost 220 lbs with only 2k lb of hitch load, so at that rate it could be as much as a 660lb loss when the hitch load is at 6k lbs..
  8. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    I meant “licensed for” as in what you’re paying for in the registration or apportioned tag or however you have the vehicle registered. I can have a class 8 freightliner Cascadia and only apportion it for 50,000 pounds, then 50,000 pounds is all I can legally gross.
  9. GypsyWanderlust
    GypsyWanderlust Medium Load Member
    386
    568
    Jan 1, 2018
    This is my last post on this thread as there are too many variables to give you a complete answer. I got that weight rating from an RV site. I will post a link from Ford for 2018 and you can go from there regarding year and model for GCWR.
    ****You are required to have a class A license for a GCWR over 26000 lbs.
    https://www.ford.com/cmslibs/conten.../pdf/guides/18RV&TT_Ford_SuperDtyPU_Nov27.pdf
    Edit: One last thing. I know you are eager to go make some money with that rig but you really need to make sure you are running safe and legal. If you get into an accident and are over weight or driving out of class the lawers will have a field day, even if you didn’t cause the accident.
  10. Ridgeline
    22,609
    120,130
    Actually I did, hotshot people think that they can exceed the oem ratings of both the trailer and the truck because they have the plates rated at some high number, the plates are meaningless unless you get them so low, you get nailed for exceeding the plate limit.
    GypsyWanderlust Thanks this.
  11. Grumppy
    3,171
    11,048
    Dec 11, 2010
    West Monroe, La
    You dont need to be so concerned about "actual" weights. Your weights are going to change here to there. Trying to work with "specific" weights is going a little overboard. All you need ot do is get round numbers & stay with that.
    Things are going to change. New/different tires, adding a new hamer here & there, throw another tarp on the truck, fuel variations, etc, etc. Over a period of a year your weight "could" change quite a bit, especially in the first year.
    You're talking about contacting Ford to get actual weights etc, is not realistic for actual daily figures. Just get your best numbers & round them off. 24,500... 16320.... etc, etc. Then get a total & then round that to a number just under that & dont ever go over it.
    The next thing is your product weight. You need to allow & round up for your product. So, in short, dont worry about specific weights. Just get the weights & round everything down, then you'll have a good round number that you know you'll always be safe picking up.... and dont deviate from that.
    When I ran hot shot, My truck GVWR was 11,400 & trailer was 20,000. That was 34,400 GCVWR. I figured all my total weights & settled on 12,000 lb gross product is what I would carry. I stayed under weight with a little room to spare, just in case the product weight was a little over somewhere.
  12. singlescrewshaker
    4,852
    42,408
    Dec 31, 2017
    Little Havana, FL
    One more thing for the OP.
    I hate to bust your chops about this, but have you put a tape on your rig & checked the overall length?
    I'm assuming once again & we all know how that works sometimes butt...
    PJ tandem duals tend to have the longest neck in the industry, @ about 106". If your running a crewcab long box new Ford, that also has the longest wheelbase in the big 3 pickup arena @175.5" I believe. I'll also assume 39" overhang from center of steer tire to front bumper. Lets do some quick math..
    Trailer--586"
    Wheelbase--175"
    Steer axle overhang--39"
    This adds up to 800" or 66' 8" overall length. That is ticket territory my friend. Truck & trailer max length law is 65'. Not all state's go by this length law, but FL definitely does. States that enforce the law will generally let you slide a couple of inches, but not almost 2 feet..
    This whole post might be useless though, as I "ASSumed" a few things..:eek:
