I started paying attention to the speed on my GPS the other day and if it's correct my speedometer is running 3 mph slow which would help explain why I haven't been very happy with my fuel mileage..
How accurate is vehicle speed on a GPS ?
Discussion in 'Experienced Truckers' Advice' started by bzinger, Jun 4, 2016.
Page 1 of 4
Pretty accurate. Unless you're going thru the mountains it will jump a few mph but for the most part my gps is 99% accurate on speed
BUMBACLADWAR, Lepton1 and bzinger Thank this. -
I've compared GPS speed to speedometer speed and find the same thing as you. The GPS speed is more accurate when approaching construction zones or toll booths than the speedometer, when they have the speed display on radar.
I put a new set of drives on last fall, and noticed about 3 mph difference at 70 mph. Now that they are worn the difference is in the 1.5 to 2 mph range.TequilaSunrise Thanks this. -
bzinger Thanks this.
Yeah, that would explain part of my owner's mortification. Here I thought it was because of the cold weather.
Many phone apps to check speed also. I have... speed view....
bzinger Thanks this. -
daf105paccar and bzinger Thank this.
It depends. But in truth if you are within 3 mph, you are safe.
The gps engine that many many units have receive a signal from at least three satellites and processes the information to output it in one second intervals. For the most part there is an error with gps units, many times a few mph. If the gps system is using a .1 or .02 timing interval, the accuracy is greatly improved.bzinger Thanks this.
Page 1 of 4
