How can I charge a laptop in the truck
Discussion in 'Questions From New Drivers' started by brendon, Oct 29, 2023.
  1. brendon
    brendon Bobtail Member
    7
    Oct 1, 2023
    I am doing CDL training soon and I've been thinking about how I have to have a PC on the road or I'll be bored out of my mind. I want an HP laptop that says it goes up to 200w, but I've read that the cigarette lighter maxes out at 150.
    If I only charge it while it's shut down and the truck is running, will that work?
  3. Bud A.
    Bud A. Road Train Member
    2,637
    16,741
    May 10, 2015
    Mountain Time
    You'll want an inverter so you can run various appliances, like the laptop, microwave, coffee pot, etc. I have a 1500w that works fine. Don't install it yourself unless you know what you're doing.
  4. Moose1958
    Moose1958 Road Train Member
    15,195
    33,504
    Dec 17, 2010
    Williesburg, Virignia
    For the last several years I drove I kept my laptop hooked up to charge while not using it. I never had any issues. I doubt you will either. I recommend however that you DO NOT use the lighter circuit. The problem is 200 watts is around 16 amps on that circuit.
  5. brendon
    7
    Oct 1, 2023
    If I pick a laptop that only goes up to 65watt, can I use the cigarette lighter? Cuz I don't know if the company will let me install stuff.
  6. Bud A.
    2,637
    16,741
    May 10, 2015
    Mountain Time
    You said you'll be training soon. Are you already planning to go to a specific company training program? If so, ask them if they have inverters in their trucks, and if not, if you can have one installed. This is not a new problem that no trucking company has ever heard of. They will have some kind of answer. A lot of companies provide inverters pre-installed in their trucks.
    The cigarette lighter is only good for small electrical loads, like charging your phone, dash cams, and GPS units.
    Also, how do you plan to plug your laptop into the cigarette lighter?
    Savor the Flavor Thanks this.
  7. tscottme
    tscottme Road Train Member
    I burned out a laptop power supply by plugging into a cig lighter inverter. If your inverter is not pure sine wave it will eventually wreck your laptop power supply. If you get a pure sine wave inverter, even a small one that plugs into cig lighter it will be ok TO RECHARGE your laptop while laptop is off. Wait until you get a job. Your company truck may already have a big power inverter installed. Many companies will not let you install your inverter, or they require they install an inverter for them to install. Mess up the inverter install and your truck will burn to the ground.
    austinmike and Bean Jr. Thank this.
  8. Bean Jr.
    Bean Jr. Road Train Member
    5,514
    9,815
    Mar 30, 2014
    I used a lighter inverter for years. My son's charger lists the draw as 0.65 amps. My HP charger says 65 watt.
  9. Ridgeline
    22,449
    117,365
    What model laptop?
    most do not exceed 100 watts.
  10. kemosabi49
    10,727
    46,146
    Jan 13, 2013
    SW Arkansas
    I second that on using a pure sine wave inverter. I tried using a modified sine wave inverter and the power supply box on my power cord would get super hot. The pure sine wave inverters cost more but may save you from having to buy another laptop.
    austinmike and tscottme Thank this.
  11. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    A pure sine isn't an absolute must. I had just a regular 1500w truck stop inverter and had the same MacBook on the truck for 8yrs without issue.
