How do I BLEND [the fuel]
Discussion in 'Questions From New Drivers' started by mateynine, Feb 7, 2019.
  1. mateynine
    mateynine Bobtail Member
    26
    12
    Sep 25, 2018
    How do I get blended fuel? Ya'know in case I ever have to head into some serious Antarctica type of S#$%. Do fuel stations up north blend fuel for you? Is it hidden in a dialog prompt? Do you have to request it at the clerk counter? 'psst, hey mistah, you got some blend? send 50/50 to pump 21'
    I know when I was running in the north east my fuel receipt always said #2 diesel, but it wasn't much colder than like -5f so just adding a little anti-gel was fine.
  3. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    We run a across the northern USA all winter long. We buy all our fuel (#2 only) at PFJ. We have APUs and trucks are configured for no-idle. We don’t even think about treating fuel unless heading into long term temps below -5 Fahrenheit. Then will dose with popular fuel treatment such as Howe’s or Power Service
    The most important thing is to
    • have filters that are changed regularly
    • Always buy quality fuel
    • Don’t go into brutal cold temps with fuel bought south of I-70
    Buying #1 fuel for USA truckers is not necessary except in extreme and rare events
    mateynine Thanks this.
  4. Brandt
    Brandt Road Train Member
    4,632
    6,368
    Sep 17, 2012
    They are supposed to blend the fuel for temps for location you buy it from. That doesn't always work so well. So you can buy anti-gel and pour it in your tanks.
    The more north you go the more they blend the fuel and I would say do a better job of it. Because it's just normal for them. We use to be able to buy #1 diesel and bled it ourselves. It hard to find #1 diesel unless you go noth, it hard to find in USA.
    When I started driving g the company would not pay for anti gel they said buy #1. If I remember correctly they said put 25 gallons in each fuel tank(they had 100 gallon tanks) basically 25% blend and we could do a 25 gallon in refer tanks that gave it a 50% blend.
    They don't really sell #1 much anymore. It always used to be a special pump just for #1. I believe in Canada they still sell just because it normal that cold.
  5. 201
    201 Road Train Member
    12,808
    26,366
    Apr 16, 2014
    high plains colorado
    Carry a little gasoline with you,,:eek: Now THAT'S old school, for ya',,
  6. Brandt
    4,632
    6,368
    Sep 17, 2012
    I can't believe the last cold spell we had the truck stops could not pump fuel. Show how bad their blends are. Unless the pumps just couldn't handle the -20F
    I remember one year it was super cold at Walcott IA I fueled at the TA. Maybe I put #1 of they still seeking it then. The Pilot truck stop across the highway had trucks fueling and gelling on the fuel island. Pilot did not blend the fuel for anything.
  7. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Know how to change your fuel filter and have the tools required to do it in case it does happen to you...
    Also a good idea to carry a red bottle of diesel 911 just in case. I carry plenty of extra anti gel, 1x911, and 2x2.5g def. Can't tell you how many times they've come in handy. Truck stop sold out and you need it. Or truck is gelling and you know you will be on side of road soon with a dead engine if you don't figure it out. So will lots of other folks. You really want to test how good that winterized sleeping bag is before you freeze...?
    Oh yeah... when you use anti gel... don't wait until it's cold out. Put it in when you fuel up. If you know you're going to somewhere colder than you are now. Avoid biodiesel. If you must buy biodiesel use extra anti gel.
    Tombstone69, mateynine and magoo68 Thank this.
  8. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Great post also like to add that if truck freezes so will apu and or bunk heater
    mateynine and roshea Thank this.
  9. Espressolane
    18,732
    117,477
    Usually put more anti-gel in the left tank, right tank is primary feed. Seems to work better that way.
    Always add treatments before fueling, that will mix it into the fuel.
    Old corn field caddy with the Cummins really liked #1.
  10. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    Or kero.
    201 Thanks this.
  11. 201
    12,808
    26,366
    Apr 16, 2014
    Yeah, I wouldn't put any gasoline in todays motors. Kerosene is just #1 anyway.
    Tombstone69 Thanks this.
