How do Truck GPS devices calculate travel time?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Leviathan Tube, Sep 13, 2020.
  1. Leviathan Tube
    Leviathan Tube Medium Load Member
    305
    140
    Mar 21, 2014
    Georgia
    Yesterday I made a trip using Trucker Path GPS app on my phone. Over a 7 hour trip, the travel time reduced by 45 minutes. It made a big difference as far as my DOT clock.
    This got me thinking again about a question I've had in the past. How do standalone devices and apps calculate travel time for big trucks? Do they simply go by the speed limit posted on each road and assume the truck can always do the speed limit? If so, this is a major flaw in my book. Many of us drive trucks with speed limiters and can't drive 85 on those roads out west. Similarly, a loaded truck going up and down the mountains is going to be traveling far below the speed limit. Do any apps and devices take this into account? Do any allow you to put your truck's maximum speed in the vehicle profile?
  3. Bean Jr.
    Bean Jr. Road Train Member
    5,539
    9,877
    Mar 30, 2014
    They use algorithms that base on the speed limit they assign for a type of road. Hammer will set a speed limit to Interstates, us highways, state and local roads. If there are us or state routes that are 4 lane freeways with 70 mph speed limits, it calculates it the same as if it were 2 lane that has 55 and goes through towns with stops and everything like that.
    Leviathan Tube Thanks this.
  4. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    My Garmin 780 sees traffic out ahead of me and will adjust the ETA based on traffic jams etc. This is via the free Garmin Smartphone link.
  5. HD_Renegade
    HD_Renegade Road Train Member
    1,470
    607
    Dec 20, 2010
    North Carolina
    Using a Garmin GPS you are able to set the MPH max to what ever you want. This way even if the posted speed limit is 80 but you can only do 70, arrival time will be off.
    I have mine set at 65, and I am governed at 72. This allows me to gain time as long as I can maintain a 65mph avor higher. It works very well.
    tscottme, Timin770 and Leviathan Tube Thank this.
  6. Leviathan Tube
    305
    140
    Mar 21, 2014
    Georgia
    That's a good feature!
  7. HD_Renegade
    1,470
    607
    Dec 20, 2010
    North Carolina
    It helps me in a lot of ways. I run a full 11 hour shift roll my 10 and go.
    Timin770 Thanks this.
  8. tscottme
    tscottme Road Train Member
    The RM 740 allows you to set an average speed it uses for calculations. It definitely DOES NOT measure your speed over several trips and then use that average speed in calculation. I think it is in the settings .
    Bean Jr. and Leviathan Tube Thank this.
  9. nredfor88
    nredfor88 Road Train Member
    1,801
    6,098
    Sep 26, 2019
    USA
    Copilot adjusts by average speed travelled. I believe it also accounts for any large variance in posted speed for long trips with multiple speeds. I’ve run calculations with the calculator and get the same time it gives me. I’ve found it to be very accurate. As I get to the target destination, it typically holds true to the estimate it gave me many miles away.
  10. Wave000
    Wave000 Light Load Member
    52
    38
    Nov 8, 2008
    USA
    SmartTruckRoute app you can set your governed mph if you not wide open also.The app is not free though. I personally like it.If there’s an issue in your route or you find something wrong they’ll fix it!
  11. Midlife Trucker
    Midlife Trucker Light Load Member
    281
    288
    Dec 3, 2011
    Shady Dale, GA
    Most GPS including CoPilot on the Qualcomm have settings in the truck profile, where you tell the software how fast you drive on different types of roads.
    Dieselboss and Bean Jr. Thank this.
