Been out here driving for over 5 years and up to now never had to split a sleeper berth time. If I ever did know I have forgotten, happens to us old farts at times. Can someone explain it clearly, how do you log it, and when are you legal for a fresh 11/14. Thanks in advance.
How do you do split sleeper properly
Discussion in 'Swift' started by inkeper, Apr 13, 2011.
Page 1 of 4
There's 2 ways. 1st one (easiest) is figure out when you start your day-- let's say midnight. Count over 14 hours make a little dot. May not drive past 14 hours. Sometime before the 14 hours ends, take a 2 hour break. All driving time before and after the 2 hour break must add up to 11 hours or less.
OK now take an 8 hour break in the sleeper. Start a new 14 hour shift. However count the hours driving before the 8 hour break and subtract from 11. This is how many hours you may now drive before taking another 2 hour break. To break this cycle, take a 10 hour break or 34 hour break.
OK the 2nd way-- start your day, we'll say midnight again and make a mark 14 hours over. Sometime before the 14 hours ends, take an 8 hour sleeper break. When you come out, make your little 14 hour dot and move it 8 hours ahead. You may not drive past this dot. Take the hours you drove before the 8 and subtract from 11. Boom, this is how much time you have left to drive before taking a 2 hour break. Now get a new 14.
My question is what if the 8 hour sleeper break goes 1 hour past the original 14, do I only get 7 hours extension on the 14 instead of 8 correct?
Forgot to mention, Swift safety wants to see a postrip and pretrip before and after each little split break. For the 8 hour break they want to see 15 minutes of bathroom time after your posttrip and 15 minutes before your pretrip as well as 8 solid hours in the sleeper so that time will add up to a total of 9 hours off plus your 2 is 11 which is why they discourage split breaking. BUT nobody told the planners lol because it seems like most loads cannot be delivered without splitting.Wolfdaddy13, TruckerNerd, Bumpy and 4 others Thank this. -
inkeper Thanks this. -
Download Drivers Daily Log. Perfect 8/2 (or 2/8) split everytime.
Seriously, I never could get it right until I had that program. They do have a free trial version.
inkeper, Tapeworm and panhandlepat Thank this. -
I lived on split sleeper with Prime.
Here's my way to explain it.
All hours since your last 10 or end of the legal break count against your 14. All driving hours since your last 10 or end of the legal break count against your 11. The 2-hr part counts against your 14. The 8-hr part does not count against your 14. Your 2 can be any combination of sleeper or off duty time. Your 8 must be continuous sleeper time.
So, you start the cycle: you pretrip and then drive 6 hours. You take a 2-hr. Right now, you have driven 6, used 8.25 of your 14. You have 5 hours of drive time left and 5.75 hours to do it in. You drive 3 hours and go to bed for 8 hours. When you are ready to roll, you do your 15-minute PTI. As of right now, you have 7 hours of drive time available and 9.75 hours to do it in. You are counting the hours from the end of your last break of two hours. Your next break can be either an 8 or a 2. You do not have to alternate 8/2 splits. Whatever it is, the hours between the last two breaks count against your available clock and, after subtracting them, you are left with your legal time, remembering the rules listed above.
You will not ever completely reset your 11/14 until you take another 10-hour break. All you are doing is pushing that time out. Even if you complete both halves of the split, time between the halves counts...plus the 2 if that's the part you just completed. The 2 does not count against you if you are adding up hours between the last two breaks and the first half is the two. You would begin adding from the end of the 2.
I have never had Swift, DOT, Prime or anybody else kick my logs back at me for not taking a pee break. I can pee in a cup in my sleeper and it counts toward sleeper time. There is no rule, written or otherwise that says what you may or may not do during sleeper berth time...only that you are in the sleeper. You could be dancing the Watusi for 8 hours as long as you do it in your sleeper berth.
There just isn't any easy way to explain it. Hope this helps.lostNfound, inkeper and panhandlepat Thank this. -
. I will just have to reread and try to digest it all. Thanks for the response.
ok im going to be the funny guy ,,,,,ha ha lol
how do ya split sleepr properly ,,,,,,,
my response is get a sawzall or chainsaw start at roof then go down back of sleeper and poof you have a split sleeper lol
Meltom Thanks this. -
i need some one to teach me to do a log book ,i want to know how to take a break n not in any rush burning up my drive time.
scottied67 and inkeper Thank this.
With this....
Splitting the sleeper should be no problem....
panhandlepat Thanks this.
Page 1 of 4
