How do you keep your battery from going dead with refrigerator running?
Discussion in 'Ask An Owner Operator' started by Flying240, May 19, 2019.
  1. Flying240
    Flying240 Light Load Member
    54
    13
    Nov 1, 2013
    Thanks! I will have to work on making sure I have enough room in the fridge for that but thanks for the idea!
    tarmadilo Thanks this.
  3. Flying240
    54
    13
    Nov 1, 2013
    I'm not sure what that is. Do you plug the fridge into it and then plug the other side to the inverter? I don't have access to electricity at the yard if it has to be plugged into an outside source.
  4. jdchet
    jdchet Medium Load Member
    540
    769
    Sep 3, 2012
    NE Ohio
    Yup! Just plug fridge into it then plug timer into inverter. I have mine set to run a few hours on Saturday night and turn back on early Monday morning. Freeze a couple of bottles of water in freezer to help keep it cold during shutdown time.
    JD
    Midwest Trucker and Flying240 Thank this.
  5. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,792
    Jan 17, 2017
    APU, Opti-idle, or shore power are the easy solutions that do not require you to empty the fridge. They all have associated costs though.
    Midwest Trucker Thanks this.
  6. Ridgeline
    22,609
    120,145
    why?
    The only thing that they do is allow more deep discharges and recharges without ruining the batteries.
    The best solution is this -
    When you park your truck, you take out all of the food that can be ruined and
    TURN OFF THE FRIDGE.​
  7. truckdriver31
    6,998
    8,359
    Sep 18, 2013
    trojan makes the best battery
  8. tarmadilo
    tarmadilo Road Train Member
    1,715
    4,718
    Dec 12, 2018
    You can fill a couple of gallon freezer bags with ice, that’s actually what I do. Bonus: they don’t leak!
    Flying240 Thanks this.
  9. uncleal13
    uncleal13 Road Train Member
    3,797
    6,296
    Apr 9, 2009
    Humboldt, Sk
    I empty out the fridge for the weekend.
    Midwest Trucker, Bean Jr. and Carlinho Thank this.
  10. PE_T
    PE_T Road Train Member
    Truck batteries were not meant to be used that way, unless you have an APU, which will turn on automatically and charge the batteries when low. Your truck batteries will go dead every time without a setup like this or similar. You can park near an outlet and use a long extension cord to keep your fridge running.
    DUNE-T Thanks this.
  11. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    You'll end up losing cranking power in the winter with them, marine batteries aren't built to work that way, I've had several different things with those pile of garbage in them.
    Farmerbob1 and DUNE-T Thank this.
