How hard is it to roll a trailer?
Discussion in 'Questions From New Drivers' started by Caynnor, Oct 18, 2013.
  1. Caynnor
    Caynnor Light Load Member
    73
    41
    Sep 29, 2013
    Covina, Ca
    On the 60 freeway in Industry there is an on ramp at Azusa Ave where I have seem trucks on their side a half dozen times in the last 18 months one just yesterday, are trailers that easy to roll or is this just a bad ramp? I drive a straight truck and have taken it fully loaded and you don't want to be moving to fast but I haven't had problems. I'm looking at schools right now to move on to an A from my B and I guess I'm getting a little paranoid.
  3. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,727
    16,492
    Jan 18, 2011
    Chill keep doin what ur doing--u already have it figured out--don't take it too quick--u can go off or on a ramp like that too slow forever--but u can only go off it too fast once.....
    But to answer your question--its not hard to roll--just requires the right amount of improper input from the loose nut behind the wheel--trailers DO NOT ROLL--drivers roll trailers
    jus sayin
  4. Chinatown
    Chinatown Road Train Member
    75,743
    173,563
    Aug 28, 2011
    Henderson, NV & Orient
    Driving too fast.
    puncher, MZdanowicz and Cetane+ Thank this.
  5. coastie
    coastie Road Train Member
    Can not say how easy it is for never done it. But as other said go to fast around a curve, to top heavy and get it in the wrong angle or hit a soft spot just right and it will go over.
  6. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Make sure your trailer is loaded correctly, secure and drive the correct speed around corners and you'll never have a problem. They post yellow speed limit caution signs on ramps. As long as your load is secure them signs will keep you safe. It's not like on the highway you can get away with 5 over. Ramps are not forgiving. If it says 15 mph you better be going 15 mph or slower. Unfortunately some drivers have to learn the hard way.
    Scientifically, speed increases the sideward G-force. Too much G-force and trailer goes boom. Don't be the driver that cuts corners (no pun intended) in the wrong places. :)
    puncher and blairandgretchen Thank this.
  7. Quickfarms
    Quickfarms Heavy Load Member
    898
    236
    May 29, 2012
    Los Angeles, Ca
    Which side?
    The southbound traffic on Azusa can move a little too fast for the ramps and they do not appear to be highway curves, they appear to be a straight curve. On a highway, or railway, curve the radius changes and the curve is banked. The result of this is that it makes you slow down going into the curve.
    blairandgretchen Thanks this.
  8. wilfredbacon15
    wilfredbacon15 Light Load Member
    277
    50
    Sep 29, 2013
    Manila, Philippines
    Just do it slowly but surely. :)
  9. blairandgretchen
    13,430
    72,407
    Dec 9, 2011
    South west Missouri
    Know your load (how it is loaded, weight, distribution), pay attention to curve, and slow down before - not IN - the ramp. The rest is physics. And a little paranoia and fear will help you every time as a new class A driver.
    Chinatown Thanks this.
  10. JohnBoy
    JohnBoy Road Train Member
    10,038
    27,202
    Apr 24, 2009
    Lake Worth, FL.
    It appears it isn't that hard at all, I see one on its side at least once a week. After 33 years of this and never having done it, I don't think I'm missing anything.
    peterd and Chinatown Thank this.
  11. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Trks aren't hard to roll,you just have to plan your ramps accordingly.There's a couple sharp ramos on my rote.Winter is the worst.Only way that ramp gets plowed is from cars.You just have to go slow.Speed says 25 go 15 to 20 mph.You haul tanker,you go slower then that at least I do.
    peterd Thanks this.
