How hard is the doubles and triples test?
Discussion in 'Questions From New Drivers' started by Bama Roadrunner, Jun 24, 2017.
  1. Bama Roadrunner
    Bama Roadrunner Light Load Member
    126
    38
    Jul 19, 2015
    North Alabama
    How hard is the doubles and triples test? I'm just curious is it hard or really easy?
  3. Bama Roadrunner
    126
    38
    Jul 19, 2015
    North Alabama
    One more question is the tanker test hard or easy?
  4. prosidius
    prosidius Light Load Member
    252
    239
    Jul 15, 2016
    Wisconsin
    Theyre both easy. Easier than any of the other tests. Alot of it is general knowledge.
  5. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,982
    18,763
    Mar 9, 2014
    In a van down by the River.
    Both are super easy if you study the guide.
  6. flyby1971
    flyby1971 Light Load Member
    297
    256
    Dec 26, 2016
    CDA ID
    As long as you study and use common sense and logic before you answer the question... Easy.
  7. MACK E-6
    48,276
    220,981
    Both tests can be aced by someone with some mechanical inclination.
  8. pattyj
    pattyj Road Train Member
    22,474
    20,136
    Jul 19, 2008
    Sioux City,ia
    Not hard at all if you study.
    Bama Roadrunner and CrappieJunkie Thank this.
  9. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    Both are easy, the triple might be a tad harder. I believe the tanker study guide was like a paragraph long
    Bama Roadrunner Thanks this.
  10. PhilKenSebben
    PhilKenSebben Light Load Member
    119
    221
    Aug 23, 2008
    Ocala, FL
    They're knowledge tests, not skills tests.
  11. tscottme
    tscottme Road Train Member
    Go to TruckersCountry.com and you can see every question on every test for every endorsement, including doubles/triples. The Doubles test seems to ask about 8 different ways which valves are open on a set of doubles? A: they are all open except for the rear-most valves. Which trailer should heavy or HazMat be loaded into. A:Front.
