How I spent $1005.00 on Alternator .
Discussion in 'Volvo Forum' started by Burdisco, Mar 29, 2022.
  1. Burdisco
    Burdisco Light Load Member
    119
    53
    Apr 25, 2015
    Alternator quit on the way back to Ontario. It died in Pa and ran on batteries back to Burlington, On.
    Luckily I run with 6 Batteries and staring with 12.8 v in Pa I was down to 12.2 v back home. I pulled the Alternator off , Friday night, and on Saturday morning the rebuilder provided me one for $276.85. No change, wtf. Back to the rebuilder, bench tested, it was check Ok, 14volts, 140 amp. He gave me a different one and bench test that 14volts,140 amps. Back on the truck on. Still no charge. Wtf. Temp -7c.
    Sunday -14c, so to the shop Monday -16c. Inderdeo Singh, 905 664 7194, $90/hr, We checked everything. F it. Run a new cable from proven source to batteries. Cables off from Starter and Alternator. New Cable from Alternator to Batteries and separate cable to starters. IMPORTANT Point *Have your keys in your Pocket* or you will spend $248 for a locksmith. I did! Wtf! when batteries reconnected doors lock. #### it!
    Singh's bill was 481.38 charging me 31/2 hrs, I got there at 9.15 left at 5, helps I am handy.
    Total cost $1005 with tax. Hurry up Spring.
    KB3MMX, austinmike, Dave_in_AZ and 2 others Thank this.
  3. MacLean
    MacLean Road Train Member
    1,364
    4,031
    Sep 12, 2017
    Or zip tie a key under the hood. At least you know most people won’t know how to find it.
    KB3MMX, Oxbow, Rideandrepair and 2 others Thank this.
  4. blairandgretchen
    13,667
    74,356
    Dec 9, 2011
    South west Missouri
    Key in my wallet - learned that one.
    Alternator in side box - would have given it to you.
    May have helped you changed it, depending on the nearest steak house.
  5. bryan21384
    bryan21384 Road Train Member
    15,460
    33,637
    Sep 18, 2009
    Memphis, TN
    If you have a Volvo, how'd you lock yourself out? Those trucks don't lock from the inside
  6. mpd240
    mpd240 Road Train Member
    1,540
    3,625
    Sep 17, 2011
    Minnesota
    I figured most of it was for gas driving to the parts store
    SmallPackage and Rideandrepair Thank this.
  7. Arctic_fox
    4,377
    23,888
    Sep 16, 2016
    I always carry 2 keys, one on my belt ring and one i keep as my primary. Also have one in a mag box inside my apu box.
    Siinman and Rideandrepair Thank this.
  8. Hayfieldmn
    Hayfieldmn Light Load Member
    158
    239
    Sep 10, 2016
    I did that about 3 years ago, im not even sure I could find it now. Probably should look some day.
  9. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    952
    1,845
    Dec 15, 2021
    Spare alternator and belts in side box is always a good idea.
  10. kranky1
    kranky1 Road Train Member
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    Right beside the AC compressor. Mine all have an alternator and AC compressor with them. Those two items seem to cost an inordinate amount of money on the road, and spare belts just goes without saying.
    North Pole Nightmare Thanks this.
  11. Flat Earth Trucker
    4,255
    16,101
    Nov 19, 2018
    New thread title:
    Gone in 63 seconds (gotta wait for the ignition to cycle, even longer if there is an air leak)
    Where do you hide your spare key?
