How long does a set of batteries last?
Discussion in 'Ask An Owner Operator' started by shatteredsquare, Nov 21, 2019.
  1. shatteredsquare
    shatteredsquare Road Train Member
    1,403
    1,832
    May 23, 2014
    middle dirt
    I rarely ever (maybe once a month) let them get low enough to trip the low voltage shut off, between the factory installed Tripac and (as of the last 6 months) a couple solar panels they never sit below 12.9v for and any length of time. Truck at 300k miles, no change in cranking behavior since new. Original set of batteries from March 2017. Never had any rotten egg smell or leakage or anything. Are they about to explode? If you keep them healthy and full do they just last indefinitely? Never had any problems at all, even this winter in the -20f polar vortex for weeks on end...
    SimpleTrucker Thanks this.
  3. Frontman
    Frontman Light Load Member
    166
    151
    Apr 4, 2012
    What brand batteries are these? You're speaking of.
  4. shatteredsquare
    1,403
    1,832
    May 23, 2014
    middle dirt
    Whatever freightliner puts in at the factory, I don't even know
  5. 062
    062 Road Train Member
    6,222
    33,477
    Oct 20, 2013
    There’s no expiration dates on batteries. Too many variables to say how long they will last.
    I have more problems in hot weather. I don’t remember the last time I had to change batteries in winter, but the last three sets I changed were in summer.
    FlaSwampRat and shatteredsquare Thank this.
  6. olddog_newtricks
    olddog_newtricks Medium Load Member
    639
    2,162
    Jun 3, 2018
    New batteries usually last 2- 3 years. Refurbished only 1 year.
    Bean Jr. and shatteredsquare Thank this.
  7. DUNE-T
    DUNE-T Road Train Member
    6,952
    16,864
    May 10, 2015
    Detroit, MI
    I have seen those Freightliner batteries last 400k miles, but usually batteries seem to be good only for 2-3 years
    shatteredsquare Thanks this.
  8. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    I have read some drivers say if you trickle charge them on weekends or when ever you are home you may get 4-5 years out of them.
    Personally I swap them out every two years just before winter.
  9. Judge
    87,966
    They last until the coldest, nastiest, worst day you can imagine. Then nothing. So you freeze while on your hands and knees wondering who in their right mind would put batteries under top step, above the bottom step. After busting knuckles, in the cold, which makes it 3x worse, and hitting back of your head on latch, I change them every two years needed or not. Preferably before winter.
  10. AModelCat
    159,412
    I wouldn't go much more than 4 personally.
    Thing a lot of folks don't realize is weak batteries kill starters. The starter will always draw the same amount of power. If the voltage is not there, it'll suck more amps (power = volts x amps). More amps, more heat. More heat, shorter starter life.
  11. SteveScott
    SteveScott Road Train Member
    4,897
    16,806
    Nov 10, 2015
    Letting your batteries run low also shortens the life of them. When I'm home I always made double sure everything is off and unplugged. I've never had the low voltage warning come on in the year since I bought the truck new.
