How long, generally, is a break-in period?
Discussion in 'Kenworth Forum' started by Dave1837, Jan 30, 2021.
  1. Dave1837
    Dave1837 Road Train Member
    1,401
    4,346
    Nov 16, 2019
    Pennsylvania
    I was issued a new truck, a very nice one at that. So far I'm pleased with it, and I'm not trying to sound non-appriciative, but it does not run good at all. It's a W900 with an X15 565/1850 Cummins and an 18 speed, and won't get out of its own way on a hill. Everyone I talk to says it needs broke in, and once it gets past the break in period it will be an animal. Is this true? If so, how many miles does that generally take?
    Trucker61016 and bzinger Thank this.
  3. Mattmanstroked
    Mattmanstroked Light Load Member
    185
    279
    Nov 24, 2019
    What gears are in the rears?
    Dave1837 Thanks this.
  4. Dave1837
    1,401
    4,346
    Nov 16, 2019
    Pennsylvania
    I'm not sure, they have to be the same as my old truck cause at 70 I'm running 1450, same as before
  5. Dave1837
    1,401
    4,346
    Nov 16, 2019
    Pennsylvania
    Great lol I thought I'd be passing everyone with a motor of that size
    Trucker61016 and Gary Muldewski Thank this.
  6. SmallPackage
    5,659
    18,089
    Dec 20, 2019
    Marion Texas
    My experiences with break in periods with big diesel engines is fuel mileage and oil consumption. Performance is either there from the beginning or its not. It doesn’t usually get stronger power wise. Fuel mileage should get better and oil usage should go down to zero if break in goes proper.
    With gas engines once we ran in the cam for 20 minutes it was full throttle fun at the track. Some guys I know never even spent the time running in the cam. It was assembly, fire up, set tune, race! Lol!
  7. AModelCat
    161,296
    I swear I was reading on here the other day the exact same question and someone piped up and said that Cummins derates them until they hit a certain hour/mileage, then they open up.
    No idea if there's truth in that or not, just something I "thought" I read on here.
    bzinger and Dave1837 Thank this.
  8. Lockport
    Lockport Light Load Member
    197
    125
    Mar 26, 2011
    Lockport, MB, CAN
    If it was a CAT, one would say "drive it like you stole it" and that was a break in. But with a Cummin's Progressive Warranty they'll only pay for the first item that breaks. All the collateral damage downstream is on you (or the carrier). Always remember though, with a Cummins, you're actually getting 2 engines. No really.
    Trucker61016 Thanks this.
  9. Dave1837
    1,401
    4,346
    Nov 16, 2019
    Pennsylvania
    I'm starting to think that's true because the truck does have a torque percentage gauge and the first day I drove it, it would only go up to 75%. Now it goes up to 80%. Also, it will build 25 lbs of boost pulling a hill, but makes 35 when the engine brake is on!! WTH lol
  10. Luke Jackson
    Luke Jackson Bobtail Member
    19
    139
    Jan 30, 2021
    How does it perform at 1600 rpm?
  11. Dave1837
    1,401
    4,346
    Nov 16, 2019
    Pennsylvania
    Not great. To get it to run decent you have to keep it wound up to 17-1800. I'm not used to running a truck like that so I find it quite annoying
    Luke Jackson and bzinger Thank this.
