How long should it take to pre-cool a trailer?
Discussion in 'Refrigerated Trucking Forum' started by reefer1021, Mar 28, 2018.
  1. reefer1021
    reefer1021 Bobtail Member
    Mar 28, 2018
    If your trailer has to be -10 and say its around 60 degrees when you turn it on, how long should it take to reach -10 degrees. It's a 1999 trailer and has a thermo king. Reefer was just gone through a couple months ago and they said it was good to go. Thanks in advance
    Captain A Thanks this.
  3. motocross25
    motocross25 Road Train Member
    3,818
    11,550
    Sep 23, 2010
    Overland Park, KS
    I pulled a newer Great Dane about a year back with a Carrier unit and from 63 to -10 it took like 2 hours. Get comfortable. That defrost cycle is a killer man. And that point from about 0 to -10 seemed like the longest part. Good luck. Think cold thoughts!
  4. CaptainDaveG
    CaptainDaveG Road Train Member
    1,478
    2,358
    Jul 31, 2014
    Fremont Wi
    At least 2 hours. I set to minus 20 and let it rip.
    Be Safe Out There
    Captain Dave
    Captain A and motocross25 Thank this.
  5. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    i set for a whole day in tx getting trl precooled to -20 for icecream
    Captain A, TruckRunner and motocross25 Thank this.
  6. Voyager1968
    Voyager1968 Road Train Member
    2,372
    2,887
    Sep 11, 2008
    I had just the opposite one time. Needed to pre-heat the trailer to 70 for a paint load. It was about 10 degrees out. I went to bed figuring I would start it in the morning when I woke up. Big mistake. I got my shower and had a cup of coffee and the dang thing was only up to 53 degrees. Luckily by the time I got to the shipper, it was up to 65 and they loaded me.
  7. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Already over 80 degrees F inside? Older trailer? (Lost R value) Bad door seals? Smaller unit not running at 100%? Hotter day? Lots of moisture in the interior air column? May take 4 hours or more, through several defrost cycles.
    There's too many variables to say with any degree of certainty
  8. TruckRunner
    TruckRunner Heavy Load Member
    704
    3,270
    Dec 21, 2017
    There are many factors involved other than just the outdoor temp. Sometimes the sun can be baking your trailer, your trailer could have air gaps on the bottom to let water out, an older reefer, etc. We have the brand new trailers that are sealed tight that use a diesel motor to power an electric reefer and that thing cools down super fast. Maybe 30 minutes at the most in any circumstance. When I see I have a freezer load I go ahead and precool on the way to the shipper.
