How long to charge batteries (running engine)?
Discussion in 'Experienced Truckers' Advice' started by tracyq144, Sep 1, 2012.
  1. tracyq144
    tracyq144 Heavy Load Member
    884
    546
    Feb 15, 2009
    MN
    Scenario: truck parked, not running, 4 batteries, less than a year old (the batteries, not me), and running the typical "cooler".
    Now, I know from experience that I can leave the cooler running for 24-25 hours with NO degradation of starting power. I'm just not willing to try it longer than that. So, that leads to...
    Question: How long would you all say that the truck needs to idle to fully recharge the batteries?
    I know that there are probably a million variables that come into this, but I am just looking for a "ball park" figure.
    Worst thing in the world to "stretch" one's hometime, and then have a dead truck.
  3. scottied67
    scottied67 Road Train Member
    10,826
    12,673
    Mar 14, 2010
    california norte
    Your truck may have a low battery shut off system which would cut all auxillary power when the batteries get down to the point where there's just enough to restart the engine.
    I have found idling doesn't charge the batts enough for another full day off the way driving down the road for just 10 miles does.
  4. Jimmy Hoffa
    Jimmy Hoffa Medium Load Member
    363
    8,014
    Dec 30, 2011
    Gold Country, California
    Mechanics told me 4hrs for my 587 Pete to fully recharge.
    VisionLogistics Thanks this.
  5. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    Also, all the blower fans and radio work to siphon off any available 'idle charge' that you may be generating. So if you're not remaining in the truck, at least turn off the cab and bunk climate control systems and this will allow for that much more juice go to the batteries.
    windsmith Thanks this.
  6. snowwy
    snowwy Road Train Member
    20,590
    13,308
    Jul 6, 2009
    i dno't have a fridge. but left my cb on while the truck sat 10 days.
    i also have a 12v digital clock that never gets unplugged.
    4 batteries half dead. almost full day of driving to recharge completely.
    last year i was in a t600. it had a fridge. sat 4 days (weekend) waiting for redatior repair. truck had to be jumped. 1 1/2 days driving to fully recharge 4 batteries.
    i think the engine has to be above 1000 rpms before the alternator starts throwing a decent charge. i drove a dump truck once. engine had to reach 1200 before the voltmeter jumped off the 12v mark. that only happend upon startup. worked fine all day long.
  7. NavigatorWife
    NavigatorWife Road Train Member
    2,937
    2,080
    Apr 30, 2012
    Cental West, AL
    Batteries when they start going dead will run out of juice a lot faster too.
    I think hubby ran the truck for at least 3hrs to recharge, but then later on had one go out then 2 more about 2 weeks later. And boy do they stink when they start going bad, like rotten eggs.
    If I was cooking, he would bring the rpm's up more also, this may have been due to the batteries having problems though.
    Is there anyway you can plug the refrig into an extension cord, or is it at a TS.
  8. Gizmo_Man
    Gizmo_Man Road Train Member
    1,226
    599
    Aug 15, 2011
    Hardly around
    eventually with this scenario, you will be over working the alternator and shorten it's life. an alternator is only supposed to "top off" the batteries. best to have whatever devices you have running, be unplugged while you are at home. why have something running when it is not needed..???
  9. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    My cooler draws 5 amps. Running for an hour, that's 5amp hours. Times 24, that's 120 amp hours drained from the battery that needs to be replaced.
    The trick here is to determine the rate at which your batteries will accept a charge. The higher the charge level, the slower they will accept a charge. The battery manufacturer may publish this data, so check to see if there's a chart that will tell you.
    Lead acid batteries typically accept 25% of their rated capacity as a charging rate. If your alternator can support that rate at your set idle speed, then use that rate to calculate time to recharge.
    Say the charging rate is 50 Amps. At that rate, it would take about 2.5 hours to fully recharge.
    Many variables, very difficult to determine without knowing the particulars of your system.
  10. windsmith
    7,296
    6,032
    Sep 2, 2011
    NEPA
    Incorrect, the alternator supports the entire electrical load of the truck while it is running, as well as charging the batteries after the engine is started.
    Running an alternator at its rated load will not shorten its life appreciably.
  11. windsmith
    7,296
    6,032
    Sep 2, 2011
    NEPA
    When I'm on hometime, I bring my cooler inside the house and run it on the 110v adapter that came with it.
    I also had problems recently with the batteries discharging overnight to the point that the truck wouldn't start, and my inverter alarmed on low voltage. What I found was corroded battery terminals on bank B (2 batteries in parallel) that had high enough resistance (8 ohms) that the batteries were not charging at all. Bank A (one battery) was fully charged, and that was the only battery that was supporting the truck. So corroded cable lugs had sapped 66% of my battery capacity. And the corrosion wasn't externally visible; the lugs had to be removed from the batteries before it could be seen. Once they were cleaned with a wire brush and emery cloth and the batteries recharged, the system was restored to full capacity.
    NavigatorWife Thanks this.
