how many cars can c4500 haull?
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by wl90.200, Nov 25, 2023.
  1. wl90.200
    wl90.200 Light Load Member
    52
    7
    Sep 22, 2022
    So the GVWR sticker is 19500 LB
    The trailer is Mini 6 car. gvwr is 48,000LB
    How do I calculate the payload?
    19,500+48,000=67,500 GCWR
    Will the truck be able to pull?
  3. Judge
    88,636
  4. Hammer166
    7,465
    27,081
    Aug 18, 2007
    ~8600+' and loving it!
    No. The GCWR on a C4500 is 24-26k.
  5. wl90.200
    52
    7
    Sep 22, 2022
    how did you find out? The sticker states 19500 LB GVWR
  6. Hammer166
    7,465
    27,081
    Aug 18, 2007
    Googled and found a pdf of the spec sheet.
    Aw crap, just looked at it again and that was for a 2005 model. Sorry!
    wl90.200 Thanks this.
  7. wl90.200
    52
    7
    Sep 22, 2022
    The GCWR depends on the trailer?
    if the truck is rated at 19,500LB.
    and hooked up to a trailer that is rated for 48,000LB
    That would give me 67,500 GCWR. GVWR+GVWR trailer
    In terms of strength, I think there is no problem. The issue is how the engine and transmission going to pull. How do I calculate that and find out?
  8. Hammer166
    7,465
    27,081
    Aug 18, 2007
    That's not how it works. The towing vehicle has a GCWR, it doesn't matter if the trailer can carry more, you're limited to the max GCWR of the towing vehicle. I would get on Chevy's fleet site, you'll find the full specs.
