How much mpg is lost running a mid-roof instead of high-rise pulling a van?
Discussion in 'Ask An Owner Operator' started by Power Meister, Oct 13, 2022.
  1. Power Meister
    Power Meister Light Load Member
    127
    91
    Jan 30, 2022
  3. Pepper24
    Pepper24 Road Train Member
    2,079
    1,600
    Dec 3, 2010
    I had a w900L flat top in 2013.The best I could do was on average 5.5 a mile for a month with the van. I also pulled a step deck trailer I could constantly stay over 6.5 I actually could average 6.8 for a month with the step.
  4. Concorde
    Concorde Road Train Member
    4,727
    16,885
    Jun 29, 2016
    West Melbourne Florida
    Lots and lots..and….how bad can it be?
    I just shut down early for the day I-80 west of Chicago about 50 miles or so.
    Head wind of 25 mph I was per dash getting 4.3 mpg.. I was only limping along at 65mph..@80k gross.
    Last trip WA to Buffalo, NY I got 6mpg with a mild tail wind.. The 6mpg was only acquired because I forced myself to run the entire trip slow. Yes I ran 67mph across SD , was difficult for me to do and it’ll never happen again :)
    389 mid-roof with dry van. Cummins 565hp with 3:55 axle ratio.. Set up for mountain driving with heavy loads..
    Quarterly ifta reports show an average of 5.20 mpg. I only idle when I have to
  5. Dino soar
    Dino soar Road Train Member
    4,791
    26,878
    Dec 8, 2017
    Just put a wing on top.
    Same difference.
  6. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,023
    Jun 17, 2018
    I know when I ran a cascadia day cab it was at least 1 mpg worse than a cascadia sleeper.
    However also note I put a turbo roof wing on my 379 and only gained like .3mpg.
  7. singlescrewshaker
    4,840
    42,283
    Dec 31, 2017
    Little Havana, FL
    Also depends on the bunk to trailer gap. If you get it sucked up tight enough your brick in the wind will be smaller..
    Truck models will make a difference as well. A FLD mid roof only stands about 10' tall, whereas a Crapcadia or 9400 Binder will be 11' tall..
    What kind of mid roof?
    A hood, or curb sniffer..
    Could also put a small wing on the tractor roof,
    or a nose bubble on the wagon to help some..
    Edit
    Guess I type slow.. lol
  8. blairandgretchen
    13,380
    71,945
    Dec 9, 2011
    South west Missouri
    What is your fuel cost as % of profit, Or - cents per mile in your operation ?
  9. Power Meister
    127
    91
    Jan 30, 2022
    None yet. I might buy a truck though.
    singlescrewshaker Thanks this.
  10. Rideandrepair
    17,344
    56,270
    Aug 8, 2015
    Adding a turbo wing, small one on a mid roof, or large one on a flat top, usually good for 1/3 to 1/2 mpg increase.
  11. abyliks
    abyliks Road Train Member
    3,896
    9,120
    May 2, 2010
    ludlow MA
    Unless you are hauling your own freight, If the difference in mpg is going to effect your bottom line that much you might want to rethink your plan all together.
    Also there is no reason to spend all that money on a truck that you hate walking out to every day
    5.41 last quarter at 80k…ish, with a 285” wheel base and a modular stand up in New England/north east
