How to deal with the noise?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by GESchaefer, Apr 3, 2023.
  1. GESchaefer
    GESchaefer Bobtail Member
    12
    11
    Dec 5, 2021
    Hi all.
    I'm in an older and loud rig.
    Weather stripping on the doors and windows are shot.
    I'm getting my ears wind blasted all day.
    Does anyone wear noise cancelling headphones all day?
    If so - are there comfortable noise cancelling headphones for all day use that ALSO lets me send / receive calls?
    Is there anything else I should be looking for to deal with the noise?
  3. Terlingua
    Terlingua Medium Load Member
    487
    1,020
    Oct 24, 2021
    Apple AirPods Pro or the Bose Quietcomfort earbuds do really well at reducing that type of noise and are a lot less noticeable than a big pair of over the ear headphones. But, wearing both sides at the same time probably isn't legal in most states.
    GESchaefer Thanks this.
  4. blairandgretchen
    13,610
    73,960
    Dec 9, 2011
    South west Missouri
    Drummer in bands for 10 years. Try this trick -
    Get some foam ear plugs and slice with a razor blade into thirds.
    Gently seat them in your ear canals, don’t shove them in.
    This would allow me to hear my kit, the bass player, but cut out the dangerous higher frequencies of the guitar and snare.
    Door seals and weather stripping is relatively inexpensive. I’m in a ‘95 so I get it.
  5. W923
    W923 Road Train Member
    1,385
    4,256
    Feb 28, 2022
    Is it your own truck? If so I would work on improving the situation.
    New weather stripping on the doors and readjusting them so they close properly will make a huge difference. If the inside is metal, find some fabric panels to cover it or carpet scraps. They also make sound deadening foam products. Ap air has rolls of it…we use it in tractor cabs and it works wonders. If it’s not your truck to work on probably the best bet is ear plugs. I would stay away from muffs because I don’t think it’s legal to have both ears obstructed.
    GESchaefer and blairandgretchen Thank this.
  6. JoeyJunk
    JoeyJunk Road Train Member
    8,762
    68,030
    Dec 31, 2010
    Washington, PA
    I am currently battling this as my FLD is loud. Just bought a pair of Bluetooth noise canceling earbuds/plugs. They were great on my end although I had to turn the CB up to max volume to hear it. First phone call to my girlfriend and she could hear lots of background noise. I had to repeat myself multiple times. Back to the drawing board.
    Flat Earth Trucker and GESchaefer Thank this.
  7. BobO1176
    BobO1176 Light Load Member
    139
    202
    Oct 29, 2021
    I wear ear plugs and if/when they start irritating me I switch to the over the ear ear muffs. When they start squeezing my head I go back to the plugs. It’s worth protecting your ears. I don’t know how accurate it is but App on my phone measuring noise reads mid 90dB when pulling hard and engine fan kicks on.
  8. Last Call
    Last Call Road Train Member
    7,568
    45,908
    Mar 15, 2021
    I have a pair of those noise canceling ear buds I use to get the same complaint if I was running equpiment or in the shop using power tools .. finally figured out that there is a noise cancellation mode.. after I read the directions it seemed to make a big difference
    Maybe yours are the same way
    Flat Earth Trucker and W923 Thank this.
  9. Terlingua
    487
    1,020
    Oct 24, 2021
    It depends on what you have. Most of the noise cancelling earbuds are not noise cancelling on the microphone, only what you hear in your ear. If you happen to have an iPhone, the recent 16.4 update added the voice isolation feature to regular phone calls, which should help a lot. Previously it was just on Facetime calls.
  10. tscottme
    tscottme Road Train Member
    For most of my trucking career I wore certain foam earplugs. I highly reccomend the Macks Slim Fit Sleep/Rest earplugs. They are easily available at Walmart or Amazon.
  11. MM71
    MM71 Heavy Load Member
    760
    991
    Jun 28, 2008
    AZ
    New weather stripping and door gaskets are pretty inexpensive. So are mufflers.
    On my w9 I did put the butyl tape window stripping you can get at the hardware store on the interior surface where the door gasket seals with the cab .... really helped seal against brutal wind.
    Also get carpet remnants for the floor. Or thick rugs. This also helps with noise
