How use refeer to charge tractor battery?
Discussion in 'Refrigerated Trucking Forum' started by Amuletox, Jan 7, 2022.
  1. Amuletox
    Amuletox Bobtail Member
    I have Thermo king reefer trying to use the refeer to jump start my tractor battery.
  3. reeferwrencher
    reeferwrencher Medium Load Member
    556
    1,474
    Aug 4, 2018
    Hook up your cables from the reefer to truck batteries.On the truck hook try to put them on opposite ends so you are on positive terminal on the first battery and negative on the fourth battery
  4. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,470
    Nov 7, 2007
    Possum Booger, Alabama
    Do not try to crank the truck with the jumper cables hooked up. Only use the reefer to charge the batteries. Leave the cables on for at least 30 minutes, remove them and try to start your truck. If it still won't crank, you probably have other issues or a shorted battery on your truck.
  5. Short Fuse EOD
    2,767
    8,631
    Jul 29, 2015
    Midwest
    When doing this better quality cables seem to help with charging wait.
  6. Magoo1968
    Magoo1968 Road Train Member
    2,028
    5,418
    Mar 18, 2021
    St Malo mb
    If you have a greased fifth wheel use both cables on the red (positive) side charge batteries for 45 minutes to a hour . Negative is only needed if you use plastic fifth wheel disk.
    ABadAzzPete Thanks this.
  7. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,602
    Nov 11, 2020
    Bad idea. Find another truck and jump start away. Jumping the reefer is one thing, but the truck is a nope in my book. Don't burn out an alternator on the most expensive piece of equipment to have breakdown.
    Get an apu. Mine will start from 10 volts, can testify
