Hypothetical question..
Discussion in 'Questions From New Drivers' started by AnthonyM757, Mar 26, 2016.
  1. AnthonyM757
    AnthonyM757 Light Load Member
    201
    93
    Sep 13, 2015
    So you're coming off the interstate onto an exit.
    You're currently going 65 mph and the exit is 25 mph..
    Do you slow down and drop each gear until you get to 7th or do you just slow down to 25 and put it in 7th??
    I was with a "trainer" on this seasonal gig I got, and he told me to drop each gear individually and not to skip shift down
  3. Chinatown
    Chinatown Road Train Member
    74,994
    170,962
    Aug 28, 2011
    Henderson, NV & Orient
    I'll bet he doesn't do it that way though.
    Straight Stacks Thanks this.
  4. tucker
    tucker Road Train Member
    12,647
    40,423
    Jun 13, 2008
    IN
    Ssshhhh.
  5. Pumpkin Oval Head
    Pumpkin Oval Head Road Train Member
    1,679
    1,155
    Jun 24, 2010
    Scranton PA
    I would use the brakes to slow down and drop it into 7th, as that is a big drop in speed and assume you would not have time to downshift thru the gears.
    A lot of exits are just too short to jake brake down to the speed limit. If you have time and distance to use the jake, go for that........it all depends on the situation.
    street beater Thanks this.
  6. Straight Stacks
    Straight Stacks Paper Cha$er
    2,930
    20,768
    Jul 18, 2015
    Alabama Gulf Coast
    He's in the sleeper anyway.
  7. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    Get on the brakes then get the gear you want for the speed you need. If you have to go from 65 to 25 in short order, down shifting each gear is taking a risk that you will miss one along the way. BTW, I double or triple down all the freaking time, 8 to 5 or 7 to 5 regularly on an 18 speed. FWIW, my truck has no jake brake.
    DsquareD and AnthonyM757 Thank this.
  8. Moose1958
    Moose1958 Road Train Member
    15,169
    33,412
    Dec 17, 2010
    Williesburg, Virignia
    In my opinion it don't really matter how you slow. The most important thing is to slow down BEFORE you get yourself in a bad situation that will result in either a rollover or leaving the road. Both can kill.
    AnthonyM757 Thanks this.
  9. tommymonza
    tommymonza Road Train Member
    4,519
    12,849
    Sep 10, 2013
    S.W. Florida
    What's the big deal in using your brakes to slow down in a short distance. Brakes are cheap to repair and far less wear and tear on the clutch, pressure plate ,transmission, universal joints, and differentials.
  10. DsquareD
    DsquareD Road Train Member
    1,439
    857
    May 21, 2009
    Green Bay, WI
    Try that (each gear) with 4500 gallons of caustic in a smooth bore tank. Besides, with a tank you would have to go 5-10 under. With a 10 speed I like to drop to 8th and then 6th. But if necessary I would just smoothly bring my speed down with the brakes and continue braking as I come out of top gear and drop it into the gear for the slower speed.
    str8t10 Thanks this.
  11. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    You drop each gear if you have enough space and time like coming up to a red light. With that short ramp, stay in gear, brake and then shift to 7th.
    I had to remind every students I train that when you need to slow down for a ramp, the main situation is to slow the truck down, not trying to get into the right gear. Almost all the students I train ALWAYS try to grab the right gear and their mind is only on that. Of course they miss and keep grinding while the truck is still doing 60mph
    otherhalftw Thanks this.
