Jumping the truck off. I'm hooking directly to the battery to battery. I don't believe the black cable is supposed to spark.?
I think I have a bad ground.
Discussion in 'Ask An Owner Operator' started by feldsforever, Jan 2, 2022.
Connect positive first, negative last.Oxbow, wore out, exhausted379 and 5 others Thank this. -
Charging batteries generates hydrogen gas, so on a quick jump, it's not a huge issue, but on a lengthy charge session it should be done. Not as important as it once was, in this era of sealed batteries, but still a good idea.Oxbow, blairandgretchen, feldsforever and 2 others Thank this. -
How long does it take to change out the four batteries under the cab?
And will four new battieries be enough to get it to start?blairandgretchen Thanks this. -
4 good batteries can crank for a long time.
When changing batteries I like to take pics before I start as well as zip tie all the cables from each terminal together to ensure they all go back in the right spots.nikmirbre, Accidental Trucker, beastr123 and 4 others Thank this. -
Milr72, beastr123, Oxbow and 1 other person Thank this.
beastr123, Oxbow and exhausted379 Thank this.
86scotty, blairandgretchen, Oxbow and 1 other person Thank this.
Way I was taught when boosting (as per mechanic school lol) is positive on the dead battery, positive on the good battery, negative on the good battery and then a ground stud or heavy metal piece away from the dead battery group. This greatly reduces the risk of a spark near the batteries. Doesn't hurt to let the battery box vent out and even fan the gas away from the batteries with a clipboard or your colouring book.
Don't spark the leads together either. Was always told that spikes the diodes in the alternator.Magoo1968, Hammer166 and blairandgretchen Thank this. -
