I'm too short to put the tarp on the flatbed
Discussion in 'Questions From New Drivers' started by Little trucker gal, Jan 20, 2025.
  1. Little trucker gal
    Little trucker gal Bobtail Member
    21
    Jan 20, 2025
    So I'm a new hire to a flatbed company. Part of orientation is to pick up the 120lb tarp and put it on the trailer. Twice. Ok. Fine. Except I'm 135lbs and only 5ft 4in. I can barely pick the #### thing up at all, much less lift it almost over my head. Any suggestions on how I can do this? They said if I can figure out a way to get it on the trailer, I'm good. Otherwise, I don't get the job.
    HELP!!!!
  3. Suspect Zero
    Suspect Zero Road Train Member
    2,521
    9,652
    Oct 10, 2016
    Brookfield, IL
    I don't know what kind of dunnage you carry, flatbed isn't my thing. But I'm thinking if there are a couple 2X4s perhaps you could lean them against the trailer like ramps and push/roll the tarp up them onto the trailer?
    But I still don't know how you'd get that thing on top of a load.
  4. 77fib77
    77fib77 Road Train Member
    11,306
    73,461
    Jul 7, 2010
    St Louis
    Put it on the drive tire first. Then get under it and get it up to the deck?
    You can pick it up get it higher on the tire. Turn it so it standing up. Push it against the deck and try to force it up and over?
    Most of the time a forklift will put them in the deck if you ask. But not always. There is always reefer.
  5. bryan21384
    bryan21384 Road Train Member
    15,389
    33,478
    Sep 18, 2009
    Memphis, TN
    That's exactly what I was going to suggest. @Little trucker gal follow this idea to get through orientation. They suggested that when I was starting out. When you get out on your own, a lot of times the forklift driver will put the tarps on top of the load for you.
  6. Big Road Skateboard
    6,655
    37,370
    May 2, 2021
    You're not gonna be able to tarp safely. You really need to look elsewhere. If you find a way to get it on the trailer just to get the job, you're gonna get yourself hurt before long.
  7. Dave1837
    Dave1837 Road Train Member
    1,401
    4,346
    Nov 16, 2019
    Pennsylvania
    Unfortunately there's not really any easy way to lift tarps. I'm not trying to be mean but if you can't get them onto the deck of the trailer what's going to happen when the shipper won't lift them onto the top of your load for you?
  8. Chinatown
    Chinatown Road Train Member
    76,740
    178,628
    Aug 28, 2011
    Henderson, NV & Orient
    How much trucking experience do you have?
    Think about during a rainstorm or blizzard and you're unloaded. Now the tarps are on the muddy ground. Can you roll them and lift them to the flatbed, then secure them.
    Switch to reefers.
  9. TX2Day
    TX2Day Medium Load Member
    612
    4,097
    Apr 24, 2023
    Texas
    Or Calistogas. But most of those companies want flatbed experience.
    You can try for the PODS account at Blackhawk, Averitt, maybe NFI still. Then all you have to do is strap. No tarps at all.
  10. tscottme
    tscottme Road Train Member
    Do they require the tarp remain rolled up during the whole lift. If not, unroll the tarp and put a few feet at a time on the deck.
    If you can get the rolled tarp onto the ICC bumper, tractor step, or top of drive or trailer tire you can get it onto your shoulder which is pretty close to deck high. You need to keep your back straight from start to finish or you will wreck your lower back. You are also going to risk bursitis in your shoulder if you lift that much weight very often.
  11. Rugerfan
    Rugerfan Road Train Member
    7,577
    38,113
    May 3, 2011
    Redding,CA
    Honestly I’d find another line of trucking to deal with. Not being mean but those tarps will only get heavier when it’s below freezing and you have to fold them instead of rolling them.
