Install air gauge on drives as scale
Discussion in 'Experienced Truckers' Advice' started by RepoweredRookie, May 21, 2023.
  1. RepoweredRookie
    RepoweredRookie Light Load Member
    152
    131
    Apr 16, 2019
    Hoping you experienced guys can help. I’m want to install a drive axel air gauge so I don’t have to drive to the Cat scale anymore. I understand the theory behind using it, BUT would it be more accurate to install a drive axle air gauge AND a trailer axle air gauge?
    Reason is I’m worried about getting overloaded by shippers. Thanks for any insight.
  3. Judge
    89,767
    Home - Right Weigh
    I’ve got air gauges on all trucks and trailers.
    Some vary on the gauges, until you figure them out.
    One trailer is 72 lb on gauge, one 62 for instance.
    But i can load them and be right by 80k
    One has digital,others are just gushed, I like the gauges better.
  4. Big Road Skateboard
    6,673
    37,513
    May 2, 2021
    Also have installed Right Weigh gauges on both. I set my trailer almost a year ago and checked it Friday. Still dead on 20230521_181300.jpg 20230521_181409.jpg 20230521_181418.jpg
  5. Coolbreezin
    Coolbreezin Medium Load Member
    403
    422
    Jun 11, 2016
    Florida
    I know Marten uses them. Call them. I didnt entirely trust them but they were pretty close to accurate.
    RepoweredRookie Thanks this.
  6. lester
    2,932
    7,935
    Jan 2, 2012
    NW, Iowa
    Having air pressure gauges on truck and trailer is never a bad idea.
    I've loaded thousands of loads of grain in a hopper using only air pressure gauge on trailer and been pretty darn accurate
  7. RepoweredRookie
    152
    131
    Apr 16, 2019
    Yeah see that’s what I want to do. Just use an air gauge from Harbor Freight/where ever and a T-fitting. Put 1 on trailer axle, 1 on drive axle for better accuracy. Right weight on 2 axles is too expensive, since I run dry van.
  8. AModelCat
    161,315
    If ya wanna get fancy, run a 3rd airline for the trailer suspension back to the truck so you don't have to leave the cab.
  9. AModelCat
    161,315
    Shouldn't need a gauge on each axle if they're all plumbed from one common levelling valve. Pressure will be the same in each bag.
  10. xsetra
    xsetra Road Train Member
    5,161
    7,093
    Aug 21, 2011
    I have Right Weigh on truck and trailer. I was told the best is an oil filled gauge.
    My air lines for the scales are T's fitted off the air bag farthest from the leveling valve.
    Good luck.
  11. RepoweredRookie
    152
    131
    Apr 16, 2019
    That’s a great idea!
