Inverter Question
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Nate_K, Jan 26, 2016.
  1. Nate_K
    Nate_K Light Load Member
    83
    71
    Dec 5, 2015
    Wisconsin
    So my truck has a 1200-2-10 Inverter.
    Is it powerful enough for a small microwave?
  3. supersnackbar
    19,124
    47,182
    Aug 19, 2007
    Your Town, USA
    Yep. Used a small microwave on a cheap truck stop 1000 watt for years
  4. EZ Money
    EZ Money Road Train Member
    A 700 watt microwave will work fine.
    I have a 900 watt microwave running off a 1500 watt inverter...It pulls about 800-1000 watts on the display while the microwave is on.Strange,it depends on whats in the oven too.
    Nate_K Thanks this.
  5. NorCenArk
    NorCenArk Light Load Member
    76
    35
    Mar 31, 2011
    Russellville, AR
    My microwave did not like a modified sine wave inverter. It would work, just not very good. My new pure sine wave inverter works the microwave much better along with everything else.
  6. EZ Money
    Yes,The pure Sine wave work much better for about everything...They are pricey though.
    They do not interfere with electronics like the TV and CB radio either.
    With my modified inverter I will lose TV reception sometimes when the microwave is on.
  7. rabbiporkchop
    9,677
    6,526
    Feb 9, 2012
    Wapwallopen, Pa
    Those numbers mean nothing without more information.
    Just googled "1200-2-10 Inverter." your post is the only thing that popped up. that inverter doesn't exist
  8. Nate_K
    83
    71
    Dec 5, 2015
    Wisconsin
    Well not sure but it shuts off after about an hour. Was charging my laptop and it went from a green light to red and decided it probably isn't worth using
  9. MidWest_MacDaddy
    11,172
    18,801
    Feb 21, 2015
    South Carolina
    We are supposed to have big inverters in our trucks pre wired... But I still have to have the engine running to operate my microwave.
  10. jimjam38
    jimjam38 Medium Load Member
    458
    73
    Nov 6, 2011
    chickasha, oklahoma
    Friend of mine gave me a power drive 1500W inverter. His truck cane with a 2000W installed and the list driver had left the power drive. Anyway, the only cables I had to test it were the battery ones that came with my power drive 300W. I got nothing on the display but the inverter did beep. I figured the wires weren't just a heavy enough gauge. I have my old 2 AWG wires figured I would use them. But this inverter also has a separate ground connection (smaller connection) I figure that one has to be hooked up as well but what gauge wire should you use?
