Inverter Questions
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Keone, Mar 13, 2009.
  1. Keone
    Keone Bobtail Member
    8
    Atlanta, Ga
    I hope this isn't a duplicate thread. I am a new driver and need to get an inverter for my electronic goodies. I was spoiled in training as my trainer had an apu. No such luck for me. I am not allowed to wire one into the tractor, so it has be one that can go into an outlet. I have looked around at them online and in the truckstops but I get lost. These things range in price from cheap to ridiculous. How do you figure out how big of one to get? Do you look at the back of the stuff you want to power and just add up watts? Who make the good ones/crappy ones? Where is the best place to buy one? The stuff I have to power is my laptop, cell phone charger, and some kind of cooler for food. The stuff I would love to power if I could is a small LCD tv I have at home and maybe my Playstation2 or XB360. Thanks for any help you can give me.
  3. Crotts Trucking
    Crotts Trucking Medium Load Member
    375
    115
    Dec 23, 2008
    Duncan, AZ
    I used a 400 watt for my laptop until it quit on me. It ran my TV also, and it was a regular TV, I would imagine it would run an LCD Ok. After that I bought a 7 or 800 watt, had no problem either. The only thing is when I Started the truck, the TV shut off, because the 12 volt power was temporarily interrupted. And also when I had my TV on, it didnt take long to start Beeping Low Battery, So I would either have to quit Watching TV, or Start the Truck. Paying for my own fuel, I usually Quit watching TV!! LOL
    I bought My 400 Watter at walmart, My 700 at flying J (I was in a bind, needed Laptop) Both under 75 bucks.
  4. skunkmonkey
    skunkmonkey Light Load Member
    58
    7
    Feb 14, 2009
    SLC, UT
    Yeah pretty much you just add up the watts usage of each of the devices you want to use and that's the inverter wattage you'd need. You want to either add some slush room or check for peak wattage of each device because if the devices spike above the inverters wattage capability something may go kaput.
    If your devices don't list wattage you can calculate it this way:
    Watts = Voltage * Amperes.
    So for example a device that uses 115 volts and 150 milliamps (0.150 amps) would use 17.25 watts.
    Crotts Trucking Thanks this.
  5. Red Fox
    Red Fox Road Train Member
    1,316
    432
    Jan 26, 2009
    Acworth, Ga.
    No ebay links
  6. Darkschneidr
    Darkschneidr Light Load Member
    296
    77
    Jan 31, 2009
    Phoenix, AZ
    I have the Cobra CPI 875 (800 RMS/1600 Peak). Pushes 7 amps (as opposed to 4 on the 400 watts). I also have the CPI 1000 (1000 RMS/3000 Peak), pushes 13 amps, but I don't use it at all.
  7. MrMustard
    MrMustard Road Train Member
    1,003
    529
    Dec 11, 2008
    Dayton, Ohio
    Baack Thanks this.
  8. Red Fox
    1,316
    432
    Jan 26, 2009
    Acworth, Ga.
    If you have wifi, and no tv, check out hulu.com - it's great.
    Here's one I haven't tried:
    ...and MovieWatcherz.com
  9. Wiseguywireless
    Wiseguywireless Road Train Member
    1,693
    801
    Dec 21, 2007
    Petoskey, MI
    I have a Cobra 1500 watt with a 3300 peak watt. It runs my Microwave, My Cook top, My George Forman Grill, the TV, Computer, Stereo for my Sat radio, Wired with 4 gage wire 4 feet long to 12 volt side of batteries, With a Breaker on the Pos. lead. At night when I am not running the engine, it will run the Stereo and TV all night and the low voltage has yet to sound.
  10. Red Fox
    1,316
    432
    Jan 26, 2009
    Acworth, Ga.
    Hey Wiseguy, why do I get a picture of you with a striped awning off the side of the truck with lawnchairs, boombox, foot massager, tv with remote and all the trimmings?
  11. Wiseguywireless
    1,693
    801
    Dec 21, 2007
    Petoskey, MI
    That day IS coming! We go camping each year and add STUFF every year. I'll get home and drive out to the Camp Grounds and I don't even have to ask what lot number they have. I look for the glow in the sky and as I get close, I see all the lights strung out. I kinda like my Trucking to be like a camping experience. Eh
