Inverter size
Discussion in 'Questions From New Drivers' started by Drpparker95, Oct 1, 2017.
  1. Drpparker95
    Drpparker95 Road Train Member
    1,445
    321
    Jan 2, 2017
    Meridian mississippi
    Hello guys i am lost. Most of the companies im looking at have at least a 1250 watt inverter. Is that enough for a small refrigerator like walmart sells
  3. mitrucker
    mitrucker Road Train Member
    5,256
    9,300
    Dec 15, 2010
    Lapeer, MI
    My suggestion would be to research power usage of the fridge. Keep in mind that it will use at least twice as much power to start up the compressor.
  4. Drpparker95
    1,445
    321
    Jan 2, 2017
    Most of them seem to require about 100 watts give or take according to the package. So a 1000 to 1200 watt should be fine for just a refrigerator and cooking appliances
  5. road_runner
    road_runner Road Train Member
    3,511
    9,029
    Mar 26, 2012
    Montucky
  6. Drpparker95
    1,445
    321
    Jan 2, 2017
    So really anything less than 1250 to 1500 is pushing it. I also have the option of a company in Jackson that has just apus but nothing else. I just cant see staying out on the road without any cooking and food appliances.
  7. Scooter Jones
    Scooter Jones Road Train Member
    9,551
    19,977
    Apr 19, 2011
    Minimum 2,000 watt. I have a 2,500 on my personal truck.
    BoostedTeg Thanks this.
  8. Drpparker95
    1,445
    321
    Jan 2, 2017
    Most company trucks come with a 1500
  9. BoostedTeg
    BoostedTeg Road Train Member
    1,775
    3,111
    Jun 2, 2008
    Boise ID
    What brand of inverter are you running? I need to install one in my truck many choices out there.
  10. Scooter Jones
    9,551
    19,977
    Apr 19, 2011
    TUNDRA.
  11. Gabru
    Gabru Light Load Member
    78
    47
    Jan 31, 2017
    Houston, TX
    @Drpparker95
    Minimum inverter size for a fridge and a microwave should be 2000 watts, in my opinion. Most inverters run at about 90% efficiency. That makes a 2000 watts inverter performing at 1800 watts without an issue. Microwave takes about 1000 watts and fridge about 600-700 watts, collectively drawing about 1700 watts.
    Also, make sure you buy a Pure Sine Wave Inverter NOT the Modified Sine Wave as the latter may damage your appliances. Choosing the right wire size is important as well since most inverters by default come with crappy wiring. For a 2000 watt inverter, I would use 1/0 AWG or 2/0 AWG (preferably) with a 250 amp fuse. Hope that helps.
