Is it legal to tow a converter dolly WITH a trailer attached to it?
Discussion in 'Trucking Industry Regulations' started by Russian Rabbit, Jul 30, 2018.
  1. Russian Rabbit
    Russian Rabbit Road Train Member
    1,701
    1,633
    Jan 3, 2016
    Is it legal to tow a converter dolly with a tractor, with a trailer on the dolly?
    In other words, you have the converter connected to the pintle hook on the tractor. Then a trailer is on the converter dolly.
    If you cannot provide a statute, then i welcome your opinion on why or why not this should be legal or not.
    i'll reveal why i'm asking later, maybe.
  3. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    I can think of reasons it shouldn't be done, not really any reasons it should be illegal to do though.
    gentleroger Thanks this.
  4. 389driver
    389driver Medium Load Member
    371
    1,035
    Feb 25, 2018
    Upstate NY
    Never mind the law. That's a bad idea due to having no weight on the drives. Hook the dolly behind the trailer.
  5. De Trucker
    De Trucker Medium Load Member
    568
    843
    Apr 21, 2015
    The pintle hooks on our tractors are only rated at 3000lbs.
    rabbiporkchop Thanks this.
  6. OLDSKOOLERnWV
    18,872
    284,466
    Sure that's not 30,000? Even a 10,000 for a heavy pickup is small. Simply asking since I have not seen it.
    S M D Thanks this.
  7. OLDSKOOLERnWV
    18,872
    284,466
    Have to agree with ya. Be like putting 25,000 on the trailer axles only and taking off on a snow covered road.
    BigBob410 Thanks this.
  8. De Trucker
    568
    843
    Apr 21, 2015
    Absolutely positive that is 3000lbs. They are meant to pull a converter dolly and nothing else.
    They aren't like the pintle hooks on the back of pups.
  9. Gearjammin' Penguin
    2,691
    8,320
    Feb 18, 2007
    Central AZ
    De Trucker is correct. You'll wind up with your subframe ripped out, dolly and trailer MIA and a lot of attention from Law Enforcement. And that's just the first 90 seconds.
    peterd, wore out, QuietStorm and 4 others Thank this.
  10. uncleal13
    uncleal13 Road Train Member
    3,797
    6,296
    Apr 9, 2009
    Humboldt, Sk
    If the truck is designed for it and has a heavy enough pintle hook, it may be okay.
    As stated most highway tractors I have seen with a pintle hook only have the light duty ones that are only designed with the thought of using it to re position an empty converter dolly. Plus the rear cross members are not heavy enough and will be ripped out. Seen it done.
    But again, if the truck was set up for it. I'd watch to make sure that the fifth on the dolly was ahead of the axle to put some weight on the truck. Otherwise it could get pretty hairy.
  11. blairandgretchen
    13,629
    74,058
    Dec 9, 2011
    South west Missouri
    Best answer.
    Wussian Wabbit - you may have to explain your thinking here.
