Is it possible to add an auxiliary fuel tank behind cab?
Discussion in 'Questions From New Drivers' started by c.w, Dec 19, 2021.
  1. Frank Speak
    Frank Speak Road Train Member
    4,560
    14,014
    May 3, 2016
    Good luck getting those trucks anytime soon. Lol
  3. Speed_Drums
    Speed_Drums Road Train Member
    1,029
    1,988
    Dec 26, 2014
    Have you considered fueling in AZ?
  4. LoneRanger
    LoneRanger Road Train Member
    3,687
    9,580
    Jun 3, 2018
    prices on the 40 near cali is crazy. Until you start getting closer to NM is when it starts to go down.
    His best bet is to move batteries under the catwalk and order bigger tanks.
  5. MacLean
    MacLean Road Train Member
    1,355
    4,001
    Sep 12, 2017
    Would it be easier / possible to remove the DEF tank and relocate it and go with a bigger fuel tank?
  6. Hammer166
    7,553
    27,495
    Aug 18, 2007
    ~8600+' and loving it!
    The ones I've seen just mount a standard tank in saddles anchored to the frame behind the sleeper. Those are already certified as fuel tanks and it's easy enough to rig up the lines and valves to gravity feed your main tanks. Or do like a lot of the pickup guys and use an electric fuel pump for transfer.
  7. c.w
    c.w Light Load Member
    105
    47
    Jun 26, 2021
    yes ,weight is ok
    yes,but at least we can out of 4 dollars area
    I m thinking about put a hand valve before T joint and always keep it close unless run out the fuel Underneath
  8. c.w
    105
    47
    Jun 26, 2021
    So where did them put the third one?
  9. c.w
    105
    47
    Jun 26, 2021
    Thanks will check it,But that would be expensive.
  10. c.w
    105
    47
    Jun 26, 2021
    I just thinking about put Rectangular tank Behind my cab,Then put a toolbox above it,Then use the frame to sustain the weight Instead of the tank
  11. flood
    flood Road Train Member
    4,167
    4,045
    Dec 25, 2010
    ever see a ARI sleeper truck....??
