Is my inverter fried?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Midnightrider909, Jan 19, 2017.
  1. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    I have a Cobra inverter that is 400 watts and about a year-and-a-half old. I was having a problem charging my cell phone and I thought it was the cord or the phone jack but last night we discovered that the Transformer plug into the inverter was on the fritz so I bought a new Transformer and soon after we started charging it it started to build up heat in the Transformer and within 10 minutes I noticed that the exhaust fan on the inverter was blowing which tipped me off to the heat problem. I unplugged it and stuck it in my other inverter and do not have a heat problem. I have a suspicion that my 400 watt inverter fried my Transformer. What do you think
  3. Jonrulerofearth
    Jonrulerofearth Light Load Member
    232
    340
    Sep 1, 2011
    Hueytown, Al
  4. Ridgeline
    22,387
    116,307
    Well Midnight, seeing I don't know what I'm talking about according a few in another part of the forum I will still post one or maybe two reasons why this happened and how to fix it.
    Outside of that, it may be toast but I reserve that determination for someone who can test it for you.
    Inverters, especially the really cheap ones (cobras fall into that group) are made with simple new designs taking advantage of a whole new group of power controllers and cheap components that really make them a lousy inverter.
    When chargers, especially ones without real transformers in them are used with these inverters, they tend to act as if there is a heavy load or something like that, which causes a lot of heat.
    Some phone chargers are made with these new power controllers too in order to eliminate the heavy or balky old type of transformer. So in order for these to work and be cheap to make, these chargers with these power controllers derive their drive signals from the pure sine wave that comes off of the AC line in the world, it can detect 50 or 60 cps but when it is a dirty signal, this is where the problem is.
    Make sense so far?
    So when these things (the phone charger) tries to regulate the voltage within the switching network in the unit, and it is messed up, it seems to go into an overload mode and heat up, usually frying out in the process.
    Back to the inverter for a moment. Cobra like Hahn and others (all come from the same place in china) seem to be a crap shoot in this case, you can have 50 good ones and then hit 20 bad ones in the same batch. The QA is really the fault of Cobra or the brander who is selling them.
    On top of that is the issue of the product you are trying to use with it, I can see in some cases products that are not cheap (some laptop supplies) will create their own drive signals within the unit and handle dirty sine wave signals while mass produced chinese things like phone chargers won't.
    The solution is one of two things;
    get a better inverter or one that has won't have dirty sine wave. Quality matters. Cobra isn't quality - it is a brand.
    BUT like I have done in the past, I just get a good quality 12 volt charger and use that, bypassing the issues of going from 12 volts to 115 back to 5 volts. IT is more stable and if taken car of, last a long long time.
    AND to add that with the USB 12 volt chargers out there, I use them a lot, they are simple circuity which seems to be more dependable and stable, can be used with a USB to phone cord which is also cheap to get.
    Dharok and Midnightrider909 Thank this.
  5. free spirited1
    free spirited1 Heavy Load Member
    981
    767
    Mar 18, 2012
    USA
    You win the award for the longest post today...lol..I couldn't help but tease ya sum....anyways, well said info
  6. aussiejosh
    aussiejosh Road Train Member
    4,709
    5,409
    Aug 28, 2009
    Airlie Beach QLd
    I've had fried eggs and bacon can't say i've ever tried fried inverters?
    free spirited1 Thanks this.
  7. Ridgeline
    22,387
    116,307
    Yeah it is a bad habit. If I condensed it, then I tend to miss something important.
    j_martell and free spirited1 Thank this.
