Is ok 4.5-5 mpg for cummins isx?
Discussion in 'Questions From New Drivers' started by Neghinam1, Nov 2, 2014.
  1. Neghinam1
    Neghinam1 Bobtail Member
    19
    Nov 2, 2014
    Hi!
    My name is Michael, i recently got new used peterbilt 387, cummins isx....2009 year
    Evrythink works perfect, except high fuel consum.....4.5 - 5 mpg....i drive reffer.....fuel, air filtres new....i have no ideea what to do, please help me. Thanks
  3. lcfd15
    lcfd15 Medium Load Member
    678
    403
    Sep 17, 2014
    Dallas/Ft. Worth, TX
    Your posting this under new drivers section?
  4. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Try thread cummins ISX technical discussion page #12 will help you get started?
  5. Fajo
    Fajo The Dark Knight
    2,214
    2,352
    Jan 26, 2013
    Boise, ID
    Could of just answered the question. Maybe he is a new driver?
    My ISX was doing the same thing. Ended up being a clogged DPF filter and a poor performing dozer injector. Back up in the high 6's low 7's in mountains. In the 8's on the flats of Nebraska.
  6. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    When did this start ?
    Since you've had it?
    Or recently..
    If it has been like that since you bought it...why did you buy it? :p
    I agree there is probably something wrong.
  7. Tall Mike
    Tall Mike Road Train Member
    7,377
    34,761
    Aug 20, 2014
    New York State
    How heavy are your loads typically ??
    Where do you run mostly, stop and go northeast ?? Out west pulling mountains ?? Down south where its mostly flat ?? How much city driving ??
    How much do you idle ??
    What RPM do you shift up ??
    What is your driving style like, do you hold it flat on the floor all the time ??
    more info please.... :-?
  8. RERM
    RERM Road Train Member
    1,683
    1,125
    Dec 13, 2012
    Chicago, IL
    What specs for truck?, what speed do you cruise?, what geography? (flat land or mountains)
    Tall Mike Thanks this.
  9. EZ Money
    EZ Money Road Train Member
    Probably a 2009 that has never had the DPF removed and baked clean.....Cummins calls for DPF service every 250k.
  10. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    You never know what the owner before you did to the engine as far as "performance enhancements". "Buy my chip, add power and increase fuel economy!" LOL
    You say everything "works perfect" ... you mean you can pull 80k over vail pass in 9th gear? If so, there's your problem. Power/torque comes at a cost in fuel burn.
    Often, these "performance boosters" do nothing to add power, but hurt fuel consumption drastically. Could have the "wrong" turbo installed, could be a lot of things. My guess is the engine is no longer at manufacturer specs due to some "super-mechaninc trucker" before you. If so, the cost to correct may be more then any fuel savings you might realize in the short term.
  11. snowwy
    snowwy Road Train Member
    20,564
    13,288
    Jul 6, 2009
    lot of questions about his driving habits, but not one question regarding type of freight.
    if he's heavy haul, then he's probably getting about average. if he's flatbedding, he'd get a little better.
    i'd be looking at the dpf, and the turbo. one truck i drove went from 4.5 to 5.75 after rebuilding turbo. turbo was just about dead. it was an 05 isx so no dpf to clean.
