Is there a way to limit thermo king reefer motor speed?
Discussion in 'Refrigerated Trucking Forum' started by xiaoqixx1, May 21, 2025.
  1. xiaoqixx1
    xiaoqixx1 Bobtail Member
    29
    8
    Jul 7, 2012
    I don't want my unit run like crazy, when they took hours to load/unload my trailer.
    Is there a way to keep the unit just low idle speed?
  3. Arctic_fox
    4,355
    23,473
    Sep 16, 2016
  4. bad-luck
    bad-luck Road Train Member
    3,359
    6,212
    Nov 16, 2013
    Baltimore, Maryland
    Yes. I have a low idle switch that was installed by my reefer mechanic.
    tscottme and Crude Truckin' Thank this.
  5. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    When you’re in the door and they open up and start loading and the unit goes nuts go out what temperature it came up to readjust your temperature setting to that temperature put it on continuous. It’ll just hum at 45° or whatever the unit says it was and when they’re done and you close the doors, then drop it back down.
    Siinman, Concorde and tscottme Thank this.
  6. Tb0n3
    Tb0n3 Road Train Member
    4,689
    9,459
    Oct 5, 2012
    Earth
    Or just turn it off because all you're doing is refrigerating their warehouse, not your trailer. The trailer will equalize with the warehouse regardless of how hard the reefer is working.
    RockinChair, Siinman, tscottme and 4 others Thank this.
  7. Chinatown
    Chinatown Road Train Member
    76,763
    178,767
    Aug 28, 2011
    Henderson, NV & Orient
    Some places don't allow the reefer to be turned off while loading.
  8. xiaoqixx1
    29
    8
    Jul 7, 2012
    Yes, keep it running, and you can avoid a lot of arguments sometimes.
    Rookie driver 956 Thanks this.
  9. Tb0n3
    4,689
    9,459
    Oct 5, 2012
    Earth
    Yeah it's not much money but for me it's the modern trailers with the roof chute that will push all the air out of the trailer and pull air from the warehouse. Maybe while the dock door is closed it'll work decently but when it's open it's doing absolutely nothing for your trailer. Probably actually detrimental.
  10. abyliks
    abyliks Road Train Member
    3,998
    9,402
    May 2, 2010
    ludlow MA
    What unit do you have? The sbs were easy to kill high speed on, precedents were no so much but still doable
    I leave my bulk head up as much as possible
  11. abyliks
    3,998
    9,402
    May 2, 2010
    ludlow MA
    and the dip #### bean counter that walked out to tell the guy next to you something irrelevant sees it not set correctly and kicks the whole load…
    Rookie driver 956 and Oxbow Thank this.
