Is there some secret to sliding tandems exactly where you want.
Discussion in 'Questions From New Drivers' started by BlackThought, Jan 30, 2017.
  1. BlackThought
    BlackThought Medium Load Member
    566
    463
    Jul 22, 2014
    Memphis,TN
    Had a pain in the ### situation yesterday and needed my tandems in a hole to be legal. Needed to slide it one hole. But after 40 minutes of trying it either went no where or slid ten holes.
    The lot was dirt and tires would drag instead of sliding. And yes the dang trailer brakes were set,I know some wise joker is gonna ask.
    In the end I got it to 33980 on drives and trailer.
  3. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    You can get pins to put in the holes in the front or back to act as stops.
    Also you may want to keep wheel chocks for that purpose.
    tscottme, Dominick253, Big Don and 2 others Thank this.
  4. RedRover
    RedRover Road Train Member
    1,794
    2,615
    Sep 10, 2016
    Corsicana, TX
    My method involves a lot of profanity and pacing back and forth up the length of the trailer until it's in the right hole.
  5. mladen86
    mladen86 Medium Load Member
    303
    269
    Aug 23, 2012
    Chicago,il
    Tandem axle stopper
  6. Chinatown
    Chinatown Road Train Member
    76,739
    178,617
    Aug 28, 2011
    Henderson, NV & Orient
    Some drivers spray water on the slide or WD-40.
    Dominick253 and Big Don Thank this.
  7. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Put some hair around the hole you want
  8. supersnackbar
    19,772
    50,717
    Aug 19, 2007
    Your Town, USA
    You have to find what name to call it...as in "you no good worthless ### #### mother ####### piece of worthless #### trailer, etc, etc." Once you call it by it's name, it will behave....:D
    But seriously, @Chinatown hit it...lube the slide rail with WD40, penetrating spray or graphite spray, including in front and behind the slide chassis assembly. Then mark where you want the pins to end up. If they don't want to slide easy, find a curb or a deep hole, release the pins and slide back and forth to spread the lube, then set your pins where you marked. If the axles are still turning instead of sliding the assembly, your brakes may be out of adjustment, and need attention. My company has air assist pin actuators and a suspension gauge for the truck axles, so once I release my pins, I set my trailer by my truck axle weight reading, then release my trailer breaks and use the trailer brake arm to lock the pins into a hole. Once I release the pins, I don't have to get out again.
    Dominick253 and Getsinyourblood Thank this.
  9. flyby1971
    flyby1971 Light Load Member
    297
    256
    Dec 26, 2016
    CDA ID
    I have a hammer I keep in the truck that the head fits perfectly in the holes. (Don't use the handle, Don't ask.) Spray some lube of your choice and slide away.
  10. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    If there's level ground that helps and also ask someone for help and doesn't have to be a driver either.You tell him what hole you want the pin in.Also make sure your Johnny bar isn't down that could have caused your trl tires to slide.
  11. BlackThought
    566
    463
    Jul 22, 2014
    Memphis,TN
