Independence wi, I'm a veteran driver of 27 yrs, this business dose not take care or repair thier equipment. my first trip, NO BRAKES, NO HEAT, I froze at.43 degrees outside, act's like Mr nice but is far from it. still not paid.
JP Enterprises. WOW.!!! BEWARE
Discussion in 'Report A BAD Trucking Company Here' started by __Gunny__, Oct 12, 2017.
After my first load.
So......you knowingly drove something that wasn't safe? The heat is bad enough, I could put on more clothes, but that would need to be addressed quickly. "But" the breaks? The truck doesn't move until they are fixed, period.
Veteran driver and Lonesome Thank this. -
I don't know what "no brakes" means.
Veteran driver, Broke Down 69, superflow and 1 other person Thank this. -
If I joined up with an outfit and they gave me a truck with no brakes but refused to fix it, I would’ve handed the keys right back.
Lonesome Thanks this. -
No brakes?
As in: "watch out lady " or no brakes like : "i can stop alittle bit "
Or no brakes like: " well its time to change the brake pads "
....we are giving you an out here otherwise these guys are gonna chew you up for driving that equipment with bad brakes, having no heat is a very small issue compared to this
And btw experience doesn't mean anything in this industry any more and not only do we have bad trucking companies we also have bad drivers to share the highway with, i should let these guys chew you to pieces but instead i will let you think about it for a minuteLast edited: Oct 12, 2017
Jonrulerofearth and Scottyboy Thank this. -
I always thought freezing didn't occur til 32 degrees. Maybe "Climate Change" has affected this!TB John Thanks this.
If I remember correctly part of the CDL licencing process was the ability to do a "pre-trip inspection". I'm pretty sure the brakes and HVAC are part of that inspection.
I guess things have changed and you just hop in a truck and take off the moment they toss you the keys.shogun, Lonesome and firemedic2816 Thank this. -
No brakes and you still left? Brakes went out after?
