Just got my engine washed. Now my crank case pressure light sensor came on??? Help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Big Lou, Aug 28, 2014.
  1. Big Lou
    Big Lou Light Load Member
    155
    25
    Aug 15, 2013
    Tampa, Florida
    Just washed motor on truck and check engine light came on. After going through the fault it says it is crank pressure. Is this a major problem or maybe the sensor got wet?? Is it OK to drive the truck. Is there a way to check it out?
  3. Johan
    Johan Light Load Member
    173
    74
    Jul 25, 2013
    Probably just need to change the filter. Shouldn't be a big deal.
    Big Lou Thanks this.
  4. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    Its things like this that I never let anyone power wash the engine. All of that wiring is not designed to withstand that much pressure.
    gokiddogo Thanks this.
  5. Big Lou
    155
    25
    Aug 15, 2013
    Tampa, Florida
    Yes true. I almost didn't let him do it. But I did and made the mistake. Drove the truck for 20 miles shut it off and now the engine light is off with no fault? Maybe water got into the filter area ? It seems fine now. Thank God! Does anyone know where the crank case filter is on a cummins isx 2010 peterbilt.
  6. Heavyd
    Heavyd Road Train Member
    7,752
    6,186
    Feb 4, 2009
  7. Pahrump
    Pahrump Medium Load Member
    filter is on the drivers side at the front close to the top of the engine,,it is about 10 x 10 in. it might be behind the power steering reservoir , has about 10 screws holding it on ,,, let you engine dry out,,the sensor plug just got wet,,BTW the filter cost about $65. If your check engine light won't go out disconnect your batteries for about 2 mins and then reconnect,,it will reset your ECM
  8. Big Lou
    155
    25
    Aug 15, 2013
    Tampa, Florida
    Will resetting the em put the fault codes in inactive status? If they go into inactive status the truck should operate normal again?
  9. Big Lou
    155
    25
    Aug 15, 2013
    Tampa, Florida
    Thanks guys! I changed the crank pressure filter. It had 90,000 miles on it. It was definitely black.
  10. Johan
    173
    74
    Jul 25, 2013
    If you fix the actual problem, i.e. get the water out of from where ever it is that caused the code in the first place, the code should go inactive on its own and the truck should run fine.
  11. Cat sdp
    Cat sdp . .
    20,854
    71,996
    Apr 8, 2012
    Orion's Belt
    What's the service interval on those.......?
    P.S. I wash my engine (myself) weekly with a garden hose and simple green, power wash 3-4 times a year.....
    Just stay away from the ECM .....
