Kenworth N14 engine fan runs constant
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Stevekw, Sep 9, 2016.
  1. blairandgretchen
    13,632
    74,081
    Dec 9, 2011
    South west Missouri
    Well - this is inexperienced thinking, but I have an N14, in a T2000, so -
    Yes, you want to sort it out - it's a huge MPG drain.
    As I understood, the AC head pressure should trigger it, but not keep it on.
    Engine temp should trigger it, though mine runs at 180 solid.
    Fan switch solenoid as said before.
    @NorthernMechanic ??
  3. AModelCat
    161,302
    A '99 likely won't have a computer controling the fan. Too old. Could be a faulty solenoid. Only things that control the fan are high A/C pressure in the high pressure side, engine temperature or the manual fan switch. I would start by checking the fan solenoid. It should not be engaged until one of the above conditions is met.
  4. Stevekw
    Stevekw Bobtail Member
    21
    Feb 26, 2016
    I replaced the intake air temp sensor didn't fix it. I jumpered the ac hi pressure switch didn't fix it. The manual switch works when I first start it, turning it on and off. So the solenoid is working as it should when the trucks idling. It's when it's going down the road that it comes on and never shuts off. Could the solenoid be operating ok when truck is idling, then not work properly as it's going down road? Solenoid is $165, not the end of the world if I buy it and it doesn't fix it, but doesn't make sense that it's bad if it works at idle. What you think?
  5. AModelCat
    161,302
    Hard to say without seeing a wiring schematic but if that A/C switch is just a 2 prong switch it may only be used to control the A/C clutch. Intake air temp likely isn't used to control the fan (I've been wrong before though). With your engine shut off but key in the run position (air pressure built to cutout as well) can you spin the fan by hand? Can you hear any noticeable air leaks around the engine area? Particularly around the fan hub and fan solenoid?
  6. Showtime89
    Showtime89 Light Load Member
    105
    106
    Feb 25, 2016
    The way my n14 red top is fan on all the time until air is shoved to it then clutch disengaged.... heres a trick for yeah .. get a air blow nozzle.... take air line off the solenoid and blow air into that line while its running.. see if you can manually shut that fan on and off... were not to sure our clutch is getting weak and will work until gets stuck then no matter how much air u give it still wont release the fan and keeps it spinning...
  7. 062
    062 Road Train Member
    6,276
    33,783
    Oct 20, 2013
    Where is the solenoid mounted?
    I wonder if the solenoid is weak, and when it gets to a certain temp its failing. Any way to put a bit of heat to it sitting still?
  8. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    Are you sure the air intake temp controls the fan? I think my cat has a separate water temp sending unit that signals the solenoid that runs the fan. If the fan works ok with the manual switch i would think the solenoid is ok
  9. Stevekw
    21
    Feb 26, 2016
    Air intake temp sensor was Kenworth maint techs idea. The fan will spin freely with key in on position, but soon as u start engine it's turning. Solenoid is mounted on firewall. No noticeable air leaks anywhere.
  10. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Why cant you plug the computer into the truck and simply see what is commanding the fan to come on.
    Engine coolant temp
    Intake air temp
    A/c high press.
    It could be a faulty engine coolant temp sensor out of range. Or the obvious of course, wiring issue.
    This is a n14 guys , the fan is commanded by the ecm. Same as a cat or detroit.
  11. Showtime89
    105
    106
    Feb 25, 2016
    I hate taking something to the dealer.... unless I am completely stumped...
    Which I am almost am to this point atm. lol
