Kenworth T660 vs T680 vs T700
Discussion in 'Ask An Owner Operator' started by SemiMan, Jun 13, 2013.
  1. SemiMan
    SemiMan Light Load Member
    60
    May 21, 2013
    Hi guys
    We are about to pick a Kenworth truck but stuck between the T660, T680, and the T700. What is the main difference between the three? All we can find is the cab size and the T680 is a little more aerodynamics. We are also thinking of picking a Ultrashift with a ratio of 3.55, and we are planning on pulling a 8 car trailer. Will this combo with a Cummins ISX 550 eng? Will the 425HP be enough to pull 8 cars cross country?
    Thank you so much
  3. Casual Trucker
    Casual Trucker Medium Load Member
    495
    326
    Sep 7, 2012
    Any engine above 400 Hp will pull 80,000 Lb Gross Wt. the more horse power you add the worse MPG you will get some times when you have the truck on cruise control and the engine needs to drop a gear to stay in the green zone the higher the HP the less likely the engine will drop that gear and it will continue to pull @ higher RPM which will Drop the fuel millage of the engine. If you want the Higher HP then you really need to skip the cruise control as much as possible.
    The best way to buy higher HP engine and keep the cost down is to get the 550 hp and then Govern the engine to 450 hp this way the engine will last a long time & the MPG will be @ best and that's my story & I'm stickin to it 10/10
  4. scottied67
    scottied67 Road Train Member
    10,816
    12,615
    Mar 14, 2010
    california norte
    Currently driving the T660 2010 Areodyne for 2 years. Very small inside but quite maneuverable. Have heard the T700 is just a T2000 with a high ceiling.
    Took a tour of the T680 the other day, nice compromise between the other 2 models, more open inside the sleeper, nice layout etc. Main thing I did not like lol was the lack of deep little pen/pencil cubby hole in the dash where I keep some pens in my truck now. T680 does have little cubby hole in dash but they are only a couple inches deep? I cannot see anything someone could put in there that will stay in there.
    By the way, I was in the KW shop getting a new defrost/A/C fan put in. The lounge was full of drivers with the newer DEF trucks waiting for their trucks to be worked on, informal survey, most of them were for emissions work and 2 guys were for driver door problems like one guy said he used the key fob lock/unlock and now door will not open at all and the other guy said his door is so bad out of alignment he's afraid to open it because it is too hard to close so these guys enter/exit out the passenger door.
    csmith1281 Thanks this.
  5. MNdriver
    MNdriver Road Train Member
    7,985
    4,371
    Feb 24, 2012
    wow, that is bad information.....
    Castrate the truck, you will lug it to pull a hill. Lugging the engine will kill your MPG faster than having it turned up to the max power setting.
    You want to get better mileage, watch your start and stops, try to avoid sudden jack-rabbit starts especially. Don't feel compelled to drive faster/slower than the sweet spot that the engine/driveline is set-up for. On the newer engines, that's around 1300 RPM.
    Khukha, csmith1281, Brandenjw and 5 others Thank this.
  6. dgc
    dgc Light Load Member
    92
    46
    Dec 2, 2012
    miami, fl
    I agree, you want max hp and keep it in the sweet spot
  7. lostriver
    lostriver Bobtail Member
    47
    19
    Jan 30, 2013
    #1- Have you ever driven a truck?
    #2- Puncuation is your friend.
    MJ1657 Thanks this.
  8. starbulk
    starbulk Bobtail Member
    21
    13
    Feb 10, 2013
    Elliottville, KY
    You are really down to a personal preference in my opinion. Pulling cars I'm guessing you are not going to be pulling the mountains of WV, MD, and PA very much? The only place you really need more HP is in the hills. What is going to be your primary operating area? Plan on going to California? Make sure you invest your money wisely for CARB regulations . I have 435HP, and except on those rare days I decide to run US 219 in PA or I-68 across western Maryland, I have no problems going anywhere. When loaded, I gross between 78-79k. You should be fine with 425HP as long as you stay out of the throttle. As for aerodynamics, are you pulling an open rack or an enclosed? Unless you are pulling enclosed, I can't imagine aerodynamics are going to help much, an open rack is going to drag when loaded I would imagine.
  9. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    my 2011 kw700 with a paccar engine 238000 miles has never had a def or door issue
  10. SemiMan
    60
    May 21, 2013
    anybody know the warranty on a brand new 2013 truck from kenworth? We read that it is 1 year/100,000 miles. Is that it? Why so low?
  11. luckylimy
    luckylimy Bobtail Member
    In Canada I just spoke to Kenworth and it was 2 Yr 250,000 miles
