Kenworth t680 12 volt or 24 volt?
Discussion in 'Questions From New Drivers' started by Chebbydriver7195, Apr 5, 2019.
  1. Chebbydriver7195
    Chebbydriver7195 Light Load Member
    113
    121
    Feb 24, 2019
    I drive a 2016 kenworth t680 with a Cummins. I had a question alternator says 12v but someone keeps arguing it's a 24volt system.
    I thought they did away with the 24v system like mid 2000s
    Dave_in_AZ Thanks this.
  3. supersnackbar
    19,477
    49,125
    Aug 19, 2007
    Your Town, USA
    The t680 with a Cummins I drove at Big G was a 12v system. Never saw a modern ecm controlled semi with a 24v, not saying they don't exist, but in 26 yrs, the only system I have ever seen was a 12v negative ground and 1 12v positive ground (old Mack pre-ecm)
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    Haven’t seen that since 1987, and it was 24 volt start, 12 volt run.
  5. Dave_in_AZ
    399,333
    Notwithstanding that, how do you like your 680 overall? What kind of mileage you getting?
  6. Chebbydriver7195
    113
    121
    Feb 24, 2019
    I like it, this transmission isn't as good as the auto in my trainers truck. I get anywhere from 6 to 9mpg. Depends on how heavy I am and the area.
    Average is 6.8 and I'm like 198 out of 325 for mpg of my fleet.
  7. SteveScott
    SteveScott Road Train Member
    4,897
    16,808
    Nov 10, 2015
    Don't go by the average fuel economy on your dash display, it's rarely correct. I come down 97 through central Oregon every week, about 315 miles and fairly flat most of the way. I always fill up at the PFJ in Biggs on the north end because it's cheap, then I top off in Klamath Falls on the south end before entering California. My display always says that I'm getting around 6.5 mpg along that route. But when I top off and calculate it out, I'm getting more like 7.6 to 8 mpg. On flat ground like on the I-5 through central California, I can get 9.3 to 10 mpg loaded. Deadhead I can get over 11 mpg. I'm driving a 2019 T680, Cummins with auto 12 speed.
    lovesthedrive Thanks this.
  8. Chebbydriver7195
    113
    121
    Feb 24, 2019
    Going off fleet info. Based on fuel, milage and idle percentage. They keep track of all of it
