Landing gear
Discussion in 'Questions From New Drivers' started by Lostmykey, Jun 14, 2021.
  1. Lostmykey
    Lostmykey Light Load Member
    189
    230
    Oct 6, 2019
    Got swapped onto me. Unless I’m trying to find the best trailer, I had only been inspecting after getting under them or checking the height if it felt off. Road breakdown said it can wait until after delivery; is it a violation to roll with it?
    Other driver dropped it loaded and took off with my good one.
    C7ED6CF2-71B7-46C1-BD0F-1746CE90FD91.jpeg 93024E04-68C5-4749-9B56-FB9B349F4AE6.jpeg
    Jaebo74 Thanks this.
    Trucking Jobs in 30 seconds
  3. Jaebo74
    Jaebo74 Medium Load Member
    433
    1,851
    Feb 4, 2021
    As long as you can get it rolled up, you're good to go.
    slow.rider and austinmike Thank this.
  4. Jaebo74
    433
    1,851
    Feb 4, 2021
    If not, make somebody fix it.
  5. Moose1958
    Moose1958 Road Train Member
    11,252
    14,478
    Dec 17, 2010
    Hampton Virginia
    That crack looks to be a bit old. I would run with it, my last few years of driving I remember yanking many trailers with bent and cracked landing gear. I may be wrong, but I don't think this is part of the CVSA OOS criteria.
  6. bad-luck
    bad-luck Road Train Member
    1,821
    2,632
    Nov 16, 2013
    Baltimore, Maryland
    Roll with it
  7. Frank Speak
    Frank Speak Road Train Member
    2,969
    8,186
    May 3, 2016
    Hot Springs, AR
    You better check with the delivery customer and make sure they’re not like Wally World and make you drop the trailer in the door and pull your truck out from under it.
  8. nredfor88
    nredfor88 Heavy Load Member
    808
    2,434
    Sep 26, 2019
    USA
    IMO, you did the right thing, notifying your road service department. They said run with it. Run with it unless you want to lose a days pay messing with getting it repaired.
    slow.rider and Jaebo74 Thank this.
  9. Milkrun
    Milkrun Light Load Member
    54
    143
    Jun 11, 2021
    Not really a hard fix. Easy to get to and just a bead weld after some persuasion.
  10. Lostmykey
    189
    230
    Oct 6, 2019
    Yep, I’m well aware that some places require dolly down and pull forward. None of the stops on my current trip do.
    I had notified after hours dispatch; I then mentioned it to my day dispatcher and he wants me to keep rolling and pickup my next preplan. I told him that breakdown explicitly told me not to drop it until at a shop… he said they would make other arrangements if needed.
    It’s all on the Qualcomm so I hope it covers my ###.
    Is it ok to fix while attached to tractor or is it preferred to drop it? Can welding mess with the tractor’s electronics?
  11. slow.rider
    slow.rider Road Train Member
    2,004
    4,607
    Apr 4, 2017
    NYC
    Some drop and hook shippers and receivers inspect landing gear before accepting a trailer. Hopefully your next stop is not one of those.
  • Draft saved Draft deleted
