Largest Rock to haul in Belly Dump
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by OldRed98, Sep 5, 2021.
  1. OldRed98
    OldRed98 Medium Load Member
    308
    251
    Apr 18, 2017
    Colorado
    Hi Everyone,
    I have a customer that wants some 2-4 inch rock. It’s a longer distance which would be nice to use my belly dump but I think I might be better off running a tandem for larger rock. Not sure it will come out of the bottom well
    I put some 1 inch rock in my belly and remember having to chain the gates tight to avoid getting stuck.
    what’s the largest rock you would put in a belly dump? Thank you
  3. Slowpoke KW
    Slowpoke KW Road Train Member
    1,170
    12,825
    Dec 7, 2015
    OK
    I’ve never pulled a belly dump but I’ve seen a bunch loading 2.5” crusher and 3”
    OldRed98 Thanks this.
  4. Cattleman84
    Cattleman84 Road Train Member
    9,946
    70,944
    Nov 1, 2017
    The Sticks, Idaho
    I've hauled 6 inch pit-run in a belly dump pup... But it was only going a few miles from the gravel pit. It did have a slight tendency to not want to start coming out very good, sometimes I had to giggle the trailer to get it flowing.
    Caterpillar Cowboy and OldRed98 Thank this.
  5. Judge
    88,546
    Guess sometimes everything needs a good giggle.
    ibcalm19, OldRed98 and Cattleman84 Thank this.
  6. Super_Trucker
    Super_Trucker Bobtail Member
    30
    89
    Feb 6, 2020
    Central Texas
    Just adjust the hatch on the bottom to open a little further if you're too worried about it
  7. OldRed98
    308
    251
    Apr 18, 2017
    Colorado
    It’s going to be 2-4 inch tracking pad. Worried those flat cut stones will come out in a chunk and bind under the trailer. I think the delivery site will only have a bobcat to push if I need it.
  8. QualityMike
    QualityMike Light Load Member
    288
    201
    Jun 19, 2011
    North Dakota
    If you can not have someone walk along and dump you a little at a time, lock all your axles and pop your gates a little at time. Reposition and start unloading again to avoid a buildup around your axles. Only pop your gates all the way open towards the end.
  9. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    607
    Nov 11, 2010
    Wyoming
    Pit run gets hauled in bellies all the time. Dumping it wide open just lock em in and don't let off hell you oughta be fine with 2-4".
  10. Magoo1968
    Magoo1968 Road Train Member
    2,035
    5,428
    Mar 18, 2021
    St Malo mb
    Watch for rocks wedged between tires after dumping. Not sure if stone is like limestone which often wedged between tires I found.
