Late Model KW and Cummins Cold Weather Plugging in
Discussion in 'Experienced Truckers' Advice' started by Midwest Trucker, Jan 26, 2019.
  1. Midwest Trucker
    5,889
    21,240
    Aug 31, 2018
    When you plug your truck in, obviously it warms the coolant and therefore the engine. But, my question is does it activate the DEF heater as well?
    I do have fuel tank heaters. Those should activate when plugged in right? Or would that be only when running like I assume the DEF heater is?
    The other night when it was -5 I treated the fuel and let it run all evening and night so it would be ready at 5am to roll. Just wondering if maybe that wasn’t necessary?
    Late Model KW and Cummins. Thanks.
  3. Bean Jr.
    Bean Jr. Road Train Member
    5,502
    9,787
    Mar 30, 2014
    Actually the block heaters heat the oil, not the coolant.
    Wargames Thanks this.
  4. AModelCat
    158,964
    The engineers have designed these systems to allow DEF to freeze and thaw. The DEF tank is thawed by engine coolant so whenever the engine is running, coolant is thawing the DEF.
  5. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    Well, I offer you this.
    One Company DM Bowman in Frederick had engine block heaters. We plugged them in every night all winter. Go home. 2 am comes around -30 ice on the ground encasing the whole truck monday AM after sitting in a ice storm all weekend it's time to crank and go.
    10 seconds on the air starter she lights and begins the usual 20 minutes of reaching 180 degrees on the water. Unplugged the heater and did the walkaround then come in to start the company paperwork and log. Rolling by 3 am. Not a problem.
    Not every time though. Once in a while we poach air off the truck next to us via glad hands emergency to fill the air starter and give er another go. Or we find that the truck is indeed completely dead as happened to me once. The shop came around bobtail, chained to my trailer pulled me out of the nosed in spot and dragged the whole deadweight with parking spring brakes locked and full 80000 pounds by brute force around to the shop to put a cannon on it driven by propane.
    Noon comes around still no start. Went home for the day with overtime in the pocket. It happens.
    Eventually that old COE got sold for a nice Mack and that one had a block heater as well. But no air start, everything was modern and depended on the batteries. I finished out the winter running into fishertown with it int he worst of ice and zero temps every morning up near Altoona. Just reliable as can be.
    That's my only experience with block heaters plug in. Everything else is high idle at 1500 if necessary to keep that fuel warm in the tank returns and the cab comfortable. No emissions anywhere because this was prior to 2001. And a few gallons spent in the coldest of winter is nothing compared to a dead truck and the expense of a tow etc.
  6. JonJon78
    JonJon78 Road Train Member
    7,154
    39,316
    Jul 1, 2018
    My heater is up where my coolant is... Had to have coolant drained for it to be installed....
  7. Bean Jr.
    5,502
    9,787
    Mar 30, 2014
    Mine is in the oil cooler, so possibly you would need to have the coolant drained, but still it warms the oil. Warm oil is what you need to be able to cold start. Engine won't crank with thick oil.
    JonJon78 Thanks this.
  8. blairandgretchen
    13,377
    71,914
    Dec 9, 2011
    South west Missouri
    S60 Detroit - in the coolant behind pump.
    By thermal scientific stuff thingy, warms block.
    Ideally a sump oil warmer would be ideal I guess, heat rises.
    Can’t help on the DEF deal though.
    -5 . Sheesh. I’d be inclined to idle the night.
    tommymonza Thanks this.
  9. AModelCat
    158,964
    Block heater heats coolant. Oil pan heater is a seperate heating element in the bottom of the oil pan. Most trucks up here come standard with both.
  10. Cat sdp
    Cat sdp . .
    20,972
    73,077
    Apr 8, 2012
    Orion's Belt
    -5F I’d feel comfortable just plugging in my block heater. Of course fuel would be bought from good supplier and treated by me ...
    Colder then that the truck runs.....
    cke, Lepton1 and blairandgretchen Thank this.
