Lay down coil securing question
Discussion in 'Flatbed Trucking Forum' started by Calregon, Dec 11, 2014.
  1. Calregon
    Calregon Light Load Member
    170
    106
    Dec 8, 2013
    Oregon
    3 laydown coils. 13200-13550 each. I used one chain forward and three back. I got a complaint from the guy that delivered the load that it was over secure and he had a hard time getting a couple binders open. (to tight) I personally want to feel comfortable and safe when hauling my load. I feel I have enough to think about without wondering if my load is secure enough on ANY road or hwy. I always think of a family driving next to me through a curvy road. What do you do? and why? Thanks for the input.
  3. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    Tell the guy that complained to jump off a high cliff and if he had a hard time getting the binders open he should not be such a puss.
    That was easy.
  4. glockwise
    glockwise Light Load Member
    253
    225
    Apr 24, 2014
    X's 2 ^^^^^
  5. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    I always over secure coils. Some guys shake their head. I dont care.
    All the lay down coils I ever did were under 10k lbs each. 6k and 8k coils. But I criss crossed 2 chains over each and then ran a strap in front of each.
    I do lots of things people say I shouldnt do or dont need to do. I hook chains to the front of pipe and steal plates or beams. I dont want to become a statistic. If I feel safe,.. then the public will be safe. My load will be safe.
    Hurst:smt111
  6. spyder7723
    spyder7723 Road Train Member
    15,471
    25,077
    Mar 31, 2013
    sarasota, fl
    This. If it didn't damage the product, it wasn't over tightened. Plain and simple.
    Stupid question of my own, what is a "laydown coil". I've always referred to them as suicide, shotgun, and eye to the sky. And then of course, little coils on pallets.
  7. White Dog
    White Dog Road Train Member
    3,161
    3,807
    Feb 11, 2008
    Iowa
    I'd picture a lay down coil, as "eye-to-the-sky" spyder.
    And I agree...if the securement did not damage the product, there is no such thing as "too much".
    Question: Why was the consignee messing with the binders any way? Isn't that the drivers job?
  8. Judge
    90,441
    No such thing as over secured as long ad you feel comfortable and no product damage, I once had a load of afco steel that I had 15 straps and 8 chains two of those had two binders one on each side because I had steel of all different lenghts and about 7 feet high but I wanted to make sure it wasn't going anywhere. I've seen several loads I wonder how they make it across town without falling off the trailer.
  9. crzyjarmans
    crzyjarmans Road Train Member
    3,314
    2,441
    Jun 9, 2010
    Home
    If coils are eve to the sky? I'd use straps instead of chains myself
  10. FwL
    FwL Medium Load Member
    438
    331
    Aug 30, 2011
    Sandpoint, ID
    Everybody needs to go back and reread the OP.
    Depends on the grade of chain used. I'd probably use at least 3 per coil, regardless... at least one forward and at least two back. I think that' s my company' s policy for minimum securement as well.
    If you want to put an extra chain on, go right ahead.
    Only way I could see that being a problem is if a binder turns so you can't get at the lever with your bar.
    Sounds like this guy just wants to complain.
  11. ReeferOhio
    ReeferOhio Medium Load Member
    596
    557
    Nov 29, 2010
    Just remember stacked skidded coils must have three points of contact, for the three coils initially talked about I would not stack them. Actually most places I go will not stack skidded coils if they weigh over 9k a piece. I haul coils every single day, any type of steel from a processing plant I've moved it. Just take your time, don't let anyone in a steel plant push you around (or other drivers waiting behind you), and secure until you feel safe (and it's legal). Safe travels.
