lcd tv.. how to mount?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by blown02GT, Jan 24, 2010.
  1. blown02GT
    blown02GT Light Load Member
    172
    24
    Aug 26, 2009
    Cecil, Ohio
    I got a 19in lcd tv today.. I don't want anything fancy, but i don't want it to fall over either.. I'm driving a KW T600 so I want to keep it in the cubby hole provided for the tv. Will the strap keep it from falling forward or backward? or is there some other way to secure it better without drilling holes somewhere? I have a few ideas, but I want to know what others have done. Thanks!
  3. wsyrob
    wsyrob Trucker Forum STAFF Staff Member
    5,769
    5,463
    Sep 14, 2007
    Winston Salem
    I built a frame for mine with plywood and 2x4's. I cut a piece of plywood to fit my cubby, then screwed some 2x4's to that. I used another piece of plywood to mount the TV to the frame using the screw holes on the back of TV. There some strap slits on the floor of the cubby hole. I drilled holes in the base plywood to match them and bolted it in.
    Baack Thanks this.
  4. CommDriver
    CommDriver Road Train Member
    1,315
    480
    Dec 9, 2006
  5. Midknight
    Midknight Light Load Member
    62
    14
    Jul 8, 2009
    Cleveland, OH
    I`m planning on making a holding bracket that will just hang on the door in my Pete 387...something that will clip over the top and maybe a strap for the bottom that wraps around the door.
  6. Gfinch
    Gfinch Bobtail Member
    36
    17
    Feb 16, 2010
    Waco, TX
    I simply built a square box with one end angled towards me slightly to fit in the TV cubby and placed a wall mount bracket on the wood box. Secure the box with the TV straps in the cubby and then place tv on wall mount bracket.
    CommDriver Thanks this.
  7. SSNVEGAS
    SSNVEGAS Bobtail Member
    13
    Las Vegas, NV
    I hang mine from the top bunk. Two 3/4" metal strip and 4 screws plus a small bungy cord. Took the strips and bent them "J", drilled four holes and hung it. Attached bungie to the strips and wrapped around vent knob. Time - 15 minutes. Cost 7 dollars. Works great and easy to remove.
  8. bigtex07
    bigtex07 Light Load Member
    238
    135
    Feb 20, 2010
    Las Vegas,NV
    hey do you have any photos of that? sounds pretty interestin
