Hi. Ive 98 Peterbilt model 378.
Weird problem occurd.
1) both signals and 4 ways working properly
2) headlights on :both signals working properly and 4 ways working properly
3) clearance lights on: right signal is working. 4 ways not working and left signal doesn't work.
98 Peterbilt model 378 Left turn signal problem while clearance lights on
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Binnie Rai, Dec 12, 2018.
Those are tough! TA/petro is pretty good at finding electrical issues
SteerTire Thanks this.
If it does it with pigtail unpluged from under truck, replace bulbs on side of tractor then replace ft. bulb? One of them is shorted out the cost of bulbs is nothing when compair to 1 hr of labor at shop?
Are all stop, tail and turn signal lights working with the lights off? If I have a turn signal out on the back of the truck I have the exact same problem. I use incandescent lights on the rear of the truck and LED everywhere else. The incandescent lights burn out fast and I can always tell when the do because the turn signals act goofy. Electricity will follow the path of least resistance and do strange things when the normal path is interrupted
I’m going to guess bad ground at the trucks taillights.
lester Thanks this.
