Letting the Turbo Cooldown vs Just Shutting the Truck Down.
Discussion in 'Experienced Truckers' Advice' started by jldilley, May 27, 2023.
  1. jldilley
    jldilley Medium Load Member
    485
    406
    Oct 13, 2013
    Indianapolis, In
    Hello, everyone. After reading an article on an old KW with a shutdown timer, I was curious: Do you let your truck run for a bit at the end of the day? I’ve heard that’s it’s hard on the turbo to simply shut the truck off after you’ve been running for the day. I haven’t been able to quite corroborate this, so I thought I would ask the more experienced hands. Thanks in advance. 5A27B823-CB58-4DCE-B5F8-686F09C35AF8.jpeg
  3. MACK E-6
    48,197
    220,242
    Back when I first heard that it was “don’t shut down immediately after a hard pull”, but just moving around the yard at the end of the day shouldn’t have anything to do with that.
  4. okiedokie
    okiedokie Road Train Member
    11,759
    85,512
    Jun 13, 2011
    PNWET
    Is there a Pyrometer in the gauge cluster? We had timers & set it for 3 mins.
  5. kemosabi49
    10,464
    44,575
    Jan 13, 2013
    SW Arkansas
    I would let it run for a few minutes to let the fluids stabilize if I had just had a hard pull. Otherwise, no.
  6. Opendeckin
    Opendeckin Medium Load Member
    447
    1,246
    May 20, 2018
    I don't shut down until the pyrometer hits 300*. During the winter it's usually already there by the time I'm off the highway and backed into a spot. During the summer it can take 3-5 minutes after parking. I personally high idle with the fan on to get there because I hate low idling an engine, but low idling works just as well for the turbo.
    The reason you need to do it is because if the turbo is 600+ degrees and you shut it down the oil left in the turbo is going to be super heated onto the turbo bearing surface which will lead to premature failure.
    Friend, Lav-25, Nostalgic and 10 others Thank this.
  7. Oxbow
    Oxbow Road Train Member
    12,539
    128,942
    Nov 24, 2015
    Same procedure here.
    Lav-25, JolliRoger, Nostalgic and 6 others Thank this.
  8. blairandgretchen
    13,253
    70,729
    Dec 9, 2011
    South west Missouri
    Couple of minutes and shut it off. Once the pyro has dropped back.
  9. Oxbow
    12,539
    128,942
    Nov 24, 2015
    I sure wish I could find shut down timers (mechanical) to purchase. I had them in trucks previously and used them every time.
  10. flood
    flood Road Train Member
    4,158
    4,023
    Dec 25, 2010
    I always idle for around 5 min after I park t9 let everything under the hood cool down and stabilize. It's better for the turbo and all the rubber hoses
  11. jldilley
    485
    406
    Oct 13, 2013
    Indianapolis, In
    Unfortunately, I do not have a pyrometer in this tractor. I am interested in getting one.
