Lifting bobtail with bottle jack
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, May 11, 2017.
  1. mitmaks
    mitmaks Road Train Member
    2,544
    2,065
    May 16, 2014
    I want to take off rims to polish them. I can put bottle jack under front axle. What about drives? Do I put bottle jack under air bag mounts?
  3. AModelCat
    154,698
    No problem as long as you've got a good jack (like a 15 ton, I like to go overkill).
    Steer axle I would put the jack under (or as close as possible to) the spring perches on the axle. No chance of hurting the axle vs in the center. I would also use a jackstand or hardwood blocking to hold the axle as jacks are not trustworthy.
    not4hire and Cottonmouth85 Thank this.
  4. AModelCat
    154,698
    I would be hesitant to go under the airbag mounts. Preferably, I would jack up the drives on the axle tube part of the housing, near where the suspension attaches to as it is a fairly stout part of the axle. Again I would support it with blocking or stands.
    Oxbow and not4hire Thank this.
  5. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Under the middle of the housing if you want to do both sides at once.
    Or under the u bolt on either side.
    Oxbow Thanks this.
  6. passingthru69
    Plus jack stands, and dump the air suspension before doing this. Safety in case. Don't want the bags to settle and pitch off the jack or stands
    Oxbow Thanks this.
  7. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    You dont even need a jack to remove the outer wheels on the drives. Two 4x4 peices or stack some 2x8" together and drive the inner tire up on them, you can easily remove the outer and the truck isnt going anywhere since the other 5 positions keep it from moving side to side. Place that did my old Classic had 2 railroad ties lined up so they could remove all 4 outers at the same time. Slick little setup.
  8. mitmaks
    2,544
    2,065
    May 16, 2014
    Great idea, will definitely try that
  9. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    While that might work with stud-piloted wheels, I'm not sure I'd do that with a hub-piloted wheel...just seems like a good way to end up having the wheels not quite centered on the hubs.
    Oxbow Thanks this.
  10. KeithT1967
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    I'm confused about what you're saying. By definition for a wheel to be "hub pilot" there cannot be any play between the hub and the wheel. If it didnt work that way you could never center the wheel on the hub when installing in any situation short of turning the entire struck on its side 90 degrees.
    Adding this.. "or unless you had some sort of device to help center the wheel"
  11. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,130
    Mar 5, 2016
    White County, Arkansas
    Bingo.
    Up she goes in the inside tires onto something high.
