Light Sleeper Going reefer??
Discussion in 'Refrigerated Trucking Forum' started by luvtotruck, Oct 2, 2013.
  1. luvtotruck
    luvtotruck Road Train Member
    1,978
    1,161
    Jul 30, 2013
    Phoenix Arizona
    Hi, I am a very light sleeper, I can wake up to the flick of a light switch, I have always been a light sleeper, So what do you suggest? Is there any extra insulation to put on the back wall of the sleeper? I have thought of putting up stuff to insulate the back of the cab? Tell me what you do!. I have tried ear plugs in while being next to a reefer but not under a load with a reefer! Thanks.
  3. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    Age of the Units is going to make a big difference....
    So that depends on who you go with.
    The newer Carrier Units are pretty quiet.
    The TK Precedent Units are supposed to be really quiet as well.
    And if you're really that light of a sleeper consider doing Dry Van, Flats or Tankers.
    Me? I do nothing..I'm NOT a light Sleeper at all..
    Some of our Older Units are annoying when I'm sitting on the Bunk...but once I go to sleep...I'm out.
    precisionpower and luvtotruck Thank this.
  4. luvtotruck
    1,978
    1,161
    Jul 30, 2013
    Phoenix Arizona
    I hear you, I'm in a bind and need to get back out there, a Reefer will take me, So I'm thinking I need to ride it! Thanks.
    Chinatown Thanks this.
  5. DsquareD
    DsquareD Road Train Member
    1,439
    857
    May 21, 2009
    Green Bay, WI
    I drove reefer for Roehl and Marten. Marten definitely had way better equipment and I hardly noticed. Roehl, (which I'm going back to BTW after taking some time off the road) had some units that were terribly loud. The trick that I used was to set it to continuous run when I slept, at least that way the engine was on all the time and I could sleep. It's the starting up that wakes me up. I just ignored messages from dispatch to change the setting until I got up.
    Sometimes I had a reefer that was so loud that I would park as far away from other trucks as possible just to be courteous. I felt bad for the last driver to show up and had to take the spot next to the noisy reefer.
  6. luvtotruck
    1,978
    1,161
    Jul 30, 2013
    Phoenix Arizona
    I appreciate this! That is a good idea! I think I could do it with the continuous run! I like your signature, "face Your Fears! Chase Your Dreams"!
  7. goingcrazy
    goingcrazy Crusty Number Cruncher
    120
    2,410
    Aug 21, 2013
    At the beach
    I'm a light sleeper, but I've found that I grow accustomed to any regular noise I hear at night. My ex-boyfriend pulls a reefer, and when I rode along with him, the first two days were awful, but after that I stopped noticing. Hopefully you will have a similar experience.
    The only other thing I might suggest, if reefer is your only choice, is to buy a white noise machine or put a white noise app on your phone and play it while you sleep. It can help counteract some of the noise of the unit.
    Puppage, luvtotruck and Grantly Thank this.
  8. morr2fab
    morr2fab Medium Load Member
    338
    110
    Oct 3, 2012
    One thing I used to do is unhook and pull out from the trailer just enough so that the truck and trailer dont touch. For me it wasnt so much the noise as it was the vibration. Some trailers are worse than others, even some new ones suck. I had an apu on my truck and that helped hide some of the noise. You do get use to it,a little. Good Luck
    luvtotruck Thanks this.
  9. Night Prowler
    Night Prowler Medium Load Member
    549
    275
    Aug 9, 2013
    Temple, Texas
    you might try a fan.
    Charli Girl Thanks this.
  10. Chinatown
    Chinatown Road Train Member
    77,265
    180,949
    Aug 28, 2011
    Henderson, NV & Orient
    Two good recommendations on here that I used also; set on continuous run & unhook and pull up just enough so there's no contact between the trailer & tractor. A co-worker would also drink a dose of Nyquil & he slept soundly and it didn't interfere with him hearing the alarm clock.
  11. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    I always slept with the TV on so background noise was never an issue.
    It seems quieter with one behind you than one beside I guess because of the exhaust blowing sidewards. If you are tired enough you will sleep. The new reefers are much quieter today.
    I would wake up if I didn't hear it after awhile.
    Panhandle flash Thanks this.
