Lightest Reefer 53
Discussion in 'Refrigerated Trucking Forum' started by czego82, Aug 31, 2015.
Lightest Reefer 53, Air Ride, Swing Door
  1. Great Dane
    16.7%
  2. Utility
    50.0%
  3. Wabash
    25.0%
  4. Vanguard
    0 vote(s)
    0.0%
  5. Hyundai
    8.3%
  1. czego82
    czego82 Light Load Member
    160
    44
    Nov 15, 2014
    Trying to find out who makes the lightest reefers. From reading around seems Great Dane will be heaviest. If you know it and can, please post weight of your reefer. Thanks
  3. rocknroll81
    rocknroll81 Road Train Member
    1,332
    930
    Sep 29, 2010
    West Allis Wi.
    Just read a recent article that the new utility 3000R weight is 13,850 with side shirts and a trl. tail
  4. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Utility 46,000 full fuel. Great Dane 45,000 3/4 tank fuel Wabash 45,400 full fuel Truck 2015 t680 paccar trailers 4 or 5 years old if this helps
    Rubberduckin Thanks this.
  5. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    The major nationwide meat haulers (a bunch of them) can't all be wrong, and they seem to lean strongly toward the Utility 3000R. Carrier Vs. Thermo-King will make a few hundred ponds difference. But to me, it seems cost/repair/warranty network would carry as much decision "weight" as weight itself.
    Nobody out there is making a "heavy reefer trailer" the last 10 years, and there are trade-offs to consider.
  6. aussiejosh
    aussiejosh Road Train Member
    4,709
    5,408
    Aug 28, 2009
    Airlie Beach QLd
    Yes with the 80,000 lb limit its easy to understand why there going for extra or should i say ultra light reefers running an extra axle would fix that issue though and raise it to 86,000lb
  7. Balakov100
    Balakov100 Road Train Member
    3,937
    2,635
    May 10, 2012
    Temple, TX
    I don't think posting weights like that does any good.
    Truck makes a huge difference.
    Only way the weight can be accurately compared is if you know the weight of the trailer by itself.
    By the way 45,000+ is very heavy.
  8. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,658
    16,026
    Jan 18, 2011
    Depends on how they are set up and how long you plan to keep em--for length of service and reliability---only 2 Ute and Dane--then personal preference comes in--both build hi/low end units--$$$ is compareable on both of the higher end specs--the plain jane 3000R--gives probably the best bang for the buck and is typically reliable--why most of the mega's use them vs the (imho)throw away Wabash--now your needs really should determine--which you ultimately purchase--Dane holds its value much more--and can cost more(depending on model)also amount of use it is going to get--doing long haul? two or less loads a week? doing regional 3-5 loads a week? The amount of times you run heavy forklifts in/out has more to do w/life of trailer than everything else combined....
    We have 8 10+y/old Danes--that have been retired from road use(mostly due to unit hours)that our local guys use for all our local p+d work(we are a long haul ltl carrier--and these trailers spend more time in a door being loaded/unloded than anything else--and the walls and floors are still going strong--so you see alot of variables...and just to throw a weight answer into the mix
    I pull a 3unit 2014 Dane Everest--Thermo King SB310--w/a 379 Pete--single tires on trailer--mt full of fuel..36k---so 44k load--BUT--have 300 gallon trk capacity and 75 gallon reefer tank--load 45k+all the time--less than 1/2 fuel--legal no worries...
  9. mwc1576
    mwc1576 Light Load Member
    83
    31
    Jun 30, 2012
    You get what you pay for. Forget a few hundred pounds here and there. Great Dane With a Thermo King reefer is the only way to go. Utility trailers are Junk. Carriers are Junk. There cheap that's why megas buy them.
  10. magoo68
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Sorry
    That's what I can haul ... Truck dry weight is 17,000
  11. Balakov100
    3,937
    2,635
    May 10, 2012
    Temple, TX
    So you're saying you can haul 45,000.
    Makes more sense that way.
    Our company runs Great Danes with Carrier Units.
    Been here close to 2 years and no real problems.
    Don't keep trailers very long so that might help.
