Log Book after extended absence from driving?
Discussion in 'Experienced Truckers' Advice' started by Truckersheldan, Aug 4, 2021.
  1. Truckersheldan
    Truckersheldan Light Load Member
    160
    91
    Jul 30, 2011
    Taneytown, Md.
    Need to know about filling in a log book after a long absence. Since retiring, I have been doing drive away for a local company. I do run a log and carry a medical card due to DOT# and weight. Recently due to the chip fiasco the trucks I deliver have been in short supply at the dealership I work for. They just got 3 in stock that I’ll be delivering this month. Newark, DE., Woodbridge, VA. and Sebring, FL. so I’m sure I’ll be seeing weigh stations. My question is, since I haven’t run for quite awhile (since the end of last year) do I have to show off duty for all the time I haven’t run? If so can I do one page, entry, and put total hours or just start with the day I actually start running again? Thanks.
    randomname Thanks this.
  3. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    One sheet covering the last seven days before the day you start working, all off-duty. Yes, fill in the hours in the end column and total to 24, e.g., 24, 0, 0, 0, 24. Put the dates in the date blank, e.g., Aug 1-7.
  4. Truckersheldan
    160
    91
    Jul 30, 2011
    Taneytown, Md.
    So I just need the last seven days. Don’t worry on any before that? That’s doable. Thanks.
  5. upnorthwpg
    upnorthwpg Road Train Member
    1,799
    2,706
    Sep 23, 2011
    That won’t work. One sheet per 24 hr period. So just fill out 7 days of logs.
    MTN Boomer Thanks this.
  6. not4hire
    7,142
    26,957
    May 16, 2012
    Calgary
    Incorrect... one page is just fine.
    395.8(f)(10)
    Recording days off duty. Two or more consecutive 24-hour periods off duty may be recorded on one duty status record.​
  7. upnorthwpg
    1,799
    2,706
    Sep 23, 2011
    Huh. Stand corrected. I think the rule is Canadian then. I know one of our guys was ticketed here for doing this.
    Rideandrepair and not4hire Thank this.
  8. Last Call
    Last Call Road Train Member
    7,568
    45,909
    Mar 15, 2021
    I tend to agree with you
    I've gotten my ### chewed before by the DOT for putting 7 off duty days on 1 page
  9. snowwy
    snowwy Road Train Member
    20,590
    13,308
    Jul 6, 2009
    You can do a whole month on one page.
    Each month requires a page.
    And since only the last 7 days is required.
    Rideandrepair, p608, kylefitzy and 3 others Thank this.
  10. supersnackbar
    19,772
    50,717
    Aug 19, 2007
    Your Town, USA
    Just put in remarks OFF DUTY from - 'start date' thru 'end date' so there a legitimate previous 7 days accounted for.
  11. not4hire
    7,142
    26,957
    May 16, 2012
    Calgary
    It is allowed in Canada as well (and I did it often without issue), although it is not showing in the most current version of the federal HOS. I don't remember if it was in the regs. and has been repealed or not, but it has always been in the CCMTA Application Guide (see below).
    SO... strictly speaking it isn't showing up in the actual HOS, but any officer writing a ticket would have to be an absolute richard cranium to do so. Having said that, I did get written once for not totalling the hours column to 24 even though my entries were 24, 0, 0, 0. :rolleyes: Yeah, they wonder why we fantasize about running them over... or maybe it's just me. :biggrin_25523:
    124. A motor carrier shall require every driver to fill out and every driver shall fill out a daily log each day that accounts for all of the driver’s on-duty time and off-duty time for that day. Would a driver be allowed to record multiple days off on a single daily log?
    Guidance: Yes.​
