looking at new reefer trailer How much insulation? Brand... opinions please
Discussion in 'Refrigerated Trucking Forum' started by bulldog36, Nov 15, 2012.
  1. bulldog36
    bulldog36 Bobtail Member
    38
    Nov 18, 2009
    looking at buying new trailer. I haul about everything including ice cream about 20% of the time. Was considering a great dane with 2.5" walls to keep temps better but wondering if not being able to turn both pallets sideways will be an problem with extra insulation. Also considering utility or wabash with 2" walls so it will be lighter and better for dry freight. Either way i will have a sb330 or 2500x2a unit. what are your thoughts on specing insulation and brands of trailers. I have a wabash right now. Also I will be moving from a 48 to a 53. Are spreads a bad idea on 53"s? I have one on my 48 and like the ride but not the extra 500lbs it brings with it. Opinions appreciated.
  3. Lilbit
    Lilbit Road Train Member
    16,583
    12,232
    Aug 4, 2008
    Let me check my logbook
    My hubby runs reefer, and he prefers Utility. The Utility trailers are lighter. He's pulled several different ones with the company he drives for, and has found the Utility to be the lightest. The sliding tandems would probably a bit easier to deal with, but there are advantages to a spread. You're already comfortable with a spread, so it won't be completely new to you.
    buddyvuk Thanks this.
  4. jbatmick
    jbatmick Road Train Member
    2,195
    2,458
    Dec 1, 2009
    hastings, Fl
    To be lighter in weight, something has to be reduced:smt115. I like pulling a lighter trailer, but if I bought one, I want a well built model, I think the 2.5 inch insulation might be a little better, especially with ice cream:icescream:. Coupla hundred pounds heavier means a little bit stouter trailer, in my book.
    Not a big fan of 53' spread, unless you run an area of the country whwere it is really needed to scale the weight.
    Had a new Wabash reefer, it was a real good trailer, but give me a Great Dane for durability:hello1:.
    Just my thinking.
  5. bulldog36
    38
    Nov 18, 2009
    I appreciate the replies. I run Midwest to west and pacific northwest. Just wondering how much 53 spread helps with loading. other opinions appreciated. One thing I don't particularly like on my Wabash is rear doors. there not near as snug as some other trailers ive seen. are the new ones any better?
  6. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,673
    16,113
    Jan 18, 2011
    My question is do u intend 2 keep this wagon 4 any length of time? Or do a standard 3-5 yr write down a dump? If u r keeping than a Dane is the only way 2 go IMHO-Seal better ride better etc--weight can b an issue--but can b compensated for--as for spreads(&I've owned many) IF u r load in ur own-especially LTL they can b very handy--BUT if u do a lot of t/l and cannot supervise etc they can b problematic scaling since 2 many loaders dont/wont listen and 2 many shippers r so anal about bridge and won't load past 48' mark--
    As for unit again IMHO i still spec an TK SB-210. Has enuff oomph 2 do the job a d is relatively fuel efficient--yes it has a smaller compressor and may require a little more maintenance but it will do the job on less fuel--especially w/hi speed circuit disabled and run on continuous for any frozen load-just set on ZERO-and it won't go into heat mode.amd just continue to.pull down rather fuel.efficiently--assuming of course the product was good n frozen when loaded.
    Just my $.02
    Lilbit Thanks this.
  7. DirtyBob
    DirtyBob Road Train Member
    1,913
    1,628
    Sep 2, 2010
    Indiana
    Having built Wabash trailers in Lafayette for a few years, I would never buy one. QC was almost non-existent. The workers always had a motto for the supervisor's view: If in doubt, ship it out.
    Travelinman Thanks this.
  8. Ukumfe
    Ukumfe Medium Load Member
    301
    515
    Oct 23, 2008
    40' from kingpin to center of rear axle in Cali. I believe you would have to go with a sliding spread or perhaps lift the rear axle ( which you won't be able to do legally when loaded heavy) Either way I would expect the CHP to always be busting your balls at the scales or just pulling you over to measure the distance if you go with a 53 spread.
  9. bulldog36
    38
    Nov 18, 2009
    I plan on keeping the trailer for 10 years. I know if I went with a spread it would have to slide for cali. Just wondering what anyone whose had one thought of them for cali. how does it work being slid that far forward. Sounds like I should stay away from wabash. Just curious what insulation packages others recommend as well for a variety of freight. I want to be able to haul as many different commodities as well, ice cream in summer included because I have a plant about 60 miles from my house and its too good of money to pass up in the summer
  10. wichris
    wichris Road Train Member
    4,247
    8,493
    Jan 17, 2011
    I have a few O/O's with 53' spreads that run CA and back every week. Some have sliders that move the whole spread,some have independent for each axle. Every once in a while they get it on the 40' but it's ignored most of the time. That violation also doesn't have points in the SMS.
  11. Lilbit
    16,583
    12,232
    Aug 4, 2008
    I pulled a bunch of brand new ones out of there during my training back in 1999. Hated that darn bean field lot!
    DirtyBob Thanks this.
