losing power 16 glider 96 engine 12.7 detroit
Discussion in 'Freightliner Forum' started by 4noReason, Sep 1, 2023.
  1. 4noReason
    4noReason Road Train Member
    2,375
    731
    Nov 29, 2012
    hey guys my truck is randomly losing power. it goes from low power to full brown strong. it sounds like its restricted on air when it does struggle. I did oil change with filters. Any idea what I should look for.
  3. Big Road Skateboard
    5,942
    31,753
    May 2, 2021
  4. 4noReason
    2,375
    731
    Nov 29, 2012
    no smoke
  5. blairandgretchen
    13,314
    71,276
    Dec 9, 2011
    South west Missouri
    Checked CAC boots - pressure test CAC system?
    Any codes? How many miles on injectors?
    4noReason Thanks this.
  6. 4noReason
    2,375
    731
    Nov 29, 2012
    no codes thx
  7. Rideandrepair
    17,267
    56,038
    Aug 8, 2015
    Maybe turbo actuator for the wastegate working intermittently? Getting stuck partially open? Big maybe.
    Elroythekid and 4noReason Thank this.
  8. Transportauto
    Transportauto Light Load Member
    100
    34
    Apr 10, 2022
    Random loss of power is electrical. if you can get data the ecm is seeing I'd watch boost pressure and throttle position.
    Seen fuel pick tube have a hold mid way up, truck would loose power and stumble when about half a tank and making turns
    Rideandrepair and 4noReason Thank this.
  9. 4noReason
    2,375
    731
    Nov 29, 2012
    it ended up being turno boost sensor. thx 4 help all
    Rideandrepair Thanks this.
  10. Elroythekid
    Elroythekid Road Train Member
    2,606
    5,663
    Sep 9, 2010
    Halifax Nova Scotia
    My 12.7 once was randomly losing power and then coming back, like a light switch on and off. Turned out to be the turbo boost pressure sensor connector was corroded. $2k at the dealer found nothing, few phone calls to the right guy, few minutes in the parking lot, and haven't had the problem since, now 4 years at least. And it Never threw a code.
    4noReason and Rideandrepair Thank this.
  11. FLHT
    FLHT Road Train Member
    1,346
    2,331
    Aug 2, 2014
    Wish I could find the guy who Knows the MX-13 ...
