Lost controller power, 2017 refer trailer w/ thermo king unit
Discussion in 'Refrigerated Trucking Forum' started by Himal2023, Oct 7, 2017.
  1. Himal2023
    Himal2023 Bobtail Member
    hi, i am an owneroperator from ohio.. i have a 2017 refer trailer with thermo king unit on it.. i was at shipper for load and running -10 At the mean time my reffer turned off and when i tried to turn back on it says lost controller power and it goes off again.. does anybody have this problem before.. and know any remedy to fix it.. any suggestions would help.. thankyou Mike
  3. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    All I can suggest is go through all the electrical harnesses you can get to and insure everything is connected well (not loose)
    Maybe put a jumper cable to it off another truck and see if this changes the result. Not sure if a component is reporting it's not getting power, or if an interrogation of the available voltage is reporting too little (bad battery)
    But there's a lot of boards in those systems that could have gone bad. Should be an error code associated with this to isolate the board reporting the error. TK helpline could probably work with this.
    Himal2023 Thanks this.
  4. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    2017 must have some warranty call tk as suggested
